Drag Racing Results - 40x results?
smok'nZ
03-02-2012, 08:35 AM
lets see some 402-408 strokers results
i know there is a 40x dyno results but dynos are gay too many T56 408's
1.84 60ft
7.506 1/8
11.555@121
was on 17" mt's
car has stock gears (3.23) and didnt like the 28" slicks also had to launch in 2 gear for it to hook on the 17's th400
MORE TO COME:drive:
badblazeSS
03-02-2012, 09:13 AM
ill let you know tomorrow hopefully
badblazeSS
03-03-2012, 09:48 PM
1.65
7.30 @ 95 in the 1/8
3875 race weight
BayAreaSS
03-07-2012, 02:25 AM
1.84 60ft
7.506 1/8
11.555@121
was on 17" mt's
MORE TO COME:drive:
You beat a modded zr1 with track times like this? lol
I told you a h/c ls1 could beat you :cool:
smok'nZ
03-07-2012, 10:09 AM
i was on 28" mt's when i raced the zr1 track i was o0n 28/10.5's which grew too much and were rubbing the fender wells and i was launching in 2nd gear with my 17's it will go 11.0's as it sits with the mt's
what does your car run? or are you too busy posting 3-4000 times?
BayAreaSS
03-07-2012, 12:24 PM
lol good one but i'm sure i've been down the track enough. My h/c ls1 making less then 430hp has ran high 10s at mid 120s mph with drag radials on my stock wheels and my car is a 6 speed.
smok'nZ
03-07-2012, 09:29 PM
what did it run first day at the track with that set up?
i heard 12's no where near 10's lets see some proof:corn:
BayAreaSS
03-07-2012, 11:19 PM
11.8 at 120+ on a pretty hot day. First time racing in 2 years and on bald tires :gruffy:
You heard wrong lol
crossbreed383
03-16-2012, 11:51 AM
408 ci
super vic
TFS heads
9.90s at 135 in Denver so far only 12 passes w 15% converter slippage
at 8000ft density altitude
would be 9teens or so at sea level
gator's 99TA
03-17-2012, 12:12 AM
10.9 @ 125 1.60 on na tune. 460 rwhp
9.74 @ 138 1.33 on about 650 rwhp.
404, ls6 heads ls6 intake stock tb, slp dual dual cat back. 28" et drags. I need to test on radials. 3.73 gear. At least 3600+ lbs. honestly just a bunch of junk thrown together.
subhumanzz
03-18-2012, 07:27 AM
9.87@136
6.26@112
average 1.33- 60'
navyblueSS
04-04-2012, 09:39 PM
10.82 @ 126 on motor 1.45 60ft.
10.04 @ 138 on 150 shot 1.68 60ft. on 275/50/15 MT DRs
About to order new Hossier 275/60 DRs, running out of gear with the 26s.
LS2 402 with Trickflow 215 heads, 3.42 gears, and 3600lbs.
odarabla
04-05-2012, 09:52 AM
LS2 402ci, reworked trick flow 215cnc heads
EPS custom cam, Th350, PTC stall, Strange
12bolt, Billet wheels on 28" tall Dr's and skinnies
in the front, Race weight is 3540lbs
1.41 60ft
6.6@101mph 1/8th
10.39@129mph 1/4
Next comes the spray..
