Done with the rebuild
Old 03-02-2012, 03:35 PM
danrun's Avatar
Default Done with the rebuild
I have a 99' trans am. Ls1, 6 speed. I had a collapsed lifter which wore a lobe in my cam.. So i decided to just tear the motor down and do somewhat of a rebuild. New GM oil pump, water pump, ls7 lifters, bee hive valve springs, tps 228r cam, ported and polished heads, GM timing chain and gears, head gaskets, and a few other gaskets. i'm pretty pleased with the setup so far, even without a tune. Not really inpressed with the power gain but a tune should help. It idles wayyy better than i thought it would, its only died 1 time. the exhaust fumes are horrible, i'm guessing because it needs a tune? overall i'm happy. i'll have a tune soon and hoping for an ls6 intake and an electric cutout.
I'll put up some pics and a video later!
Old 03-02-2012, 04:30 PM
ryobi1's Avatar
Are you running cats? If not, thats why your smelling exhaust.
Old 03-02-2012, 07:35 PM
danrun's Avatar
I'm not. I never smelled them before though.
Old 03-03-2012, 10:01 PM
danrun's Avatar
i've put almost 300 miles on the car since all the work was done. they were pretty easy miles but now i'm hearing a ticking noise in the top end that sounds like a lifter again. say it aint so
Old 03-06-2012, 12:42 PM
danrun's Avatar
Just dropped back off at the me mechanic. On the way there it started making all kinds of racket. More of a knock and scratch sound so I called him an he sent a tow truck. He thinks it's either a broke rod or piston or both. Could my luck go any worse? Shew
Old 03-06-2012, 01:14 PM
KevinR's Avatar
Did you ever get it tuned? Did you go WOT at all?
Old 03-06-2012, 01:58 PM
danrun's Avatar
It's still not tuned. It's not been over 5k
Old 03-06-2012, 02:10 PM
KevinR's Avatar
Did you torque everything properly? Also, did you change out the pushrods, or did you keep the stock ones?
Old 03-06-2012, 02:43 PM
danrun's Avatar
Everything is tourqued down properly. It already had chromoly hardened pushrods and they were good so I left them in there. We took the passenger side valve cover off hoping for something simple but we seen nothing
