Corvette Performance - 04Z06 trans leak
redsscamaroboy
03-02-2012, 07:37 PM
Can anyone recommend a shop in Knoxville, TN to take my C5 Z06 to, for a fluid leak from my transmission.
Had output shaft seals replaced as a stipulation of the used car purchase.
I have a Monster stage 2 clutch kit NIB waiting to be installed.
Maybe I could get both done at the same time.
Thanks for your help,
Dave
bearcatt
03-03-2012, 02:26 PM
Wish I could tell you where there is a good shop in your area.
Have you tried the regional area part of LS1Tech ?
redsscamaroboy
03-04-2012, 05:21 PM
Good idea,that's my next step.
bearcatt
03-04-2012, 06:48 PM
With the transmission and axles out, that would be the best time to replace any seal(s) that might be leaking.
I used to pull the trans all the time when I had my F-body because it wasn't to bad once you got used to it. A clutch replacement on a Vette is alot more work, especially doing it on the ground with jackstands.
When clutch time comes near for my 04Z, I will decide if I will pay someone or do it myself.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
