Rick-LS1
03-02-2012, 08:55 PM
Arai VX Pro 3 Red Narita Replica /size Medium (57-58cm)
The Arai VX Pro 3 Helmet Narita 3 Red is an updated version of Arai's VX-Pro considered by many as the off road helmet all others should be judged. Arai found ways to improve upon their already great helmet with the Arai VX Pro 3 to give you added safety and confidence.
Arai VX Pro 3 Helmet Narita 3 Red Features
• Complex Laminate Construction (clc) shell technology achieves a strong, flexible shell in a lightweight package
• Redesigned peak forces more air into the forehead vents for improved cooling while reducing bucketing at higher speeds
• Additional 11mm of forward tilt in the chin bar area to give a more open feeling without changing the length or radius of the chin bar for minimized protrusion
• One piece grill with vent gate to allow control of airflow to the chin area
• Rounded chin bar shape makes digging in or catching during a spill less likely than other designs
• Diffuser ventilation design that creates a tremendous amount of venturi vacuum at the rear
• Emergency cheek pad release system allows medical personnel to easily remove helmet from an injured rider
• Fully removable/washable dry cool lining material utilizes micro water cells to improve moisture and heat transfer from your head leaving you drier and cooler. Also allows liner to dry faster between rides
In like new condition no scratches. Asking $380.00 Or best offer
http://img.photobucket.com/albums/v484/rickls1/DSC02316.jpg
http://img.photobucket.com/albums/v484/rickls1/DSC02315.jpg
