Gen 5 Camaro Power-Adder Tech - ProCharger F-1X available for 2010+ Camaro SS
Bob@BruteSpeed
03-02-2012, 09:00 PM
http://shop.brutespeed.com/2010-12-Camaro-SS_c7.htm
The new F-1X head unit is available on three cog kits available through Brute Speed. Bob
http://shop.brutespeed.com/ATI-1GT200-F1X-Non-Intercooled-Cog-Race-Kit-F-1C-F-1R-F-1X-ATI-1GT200-F1XC.htm
http://shop.brutespeed.com/ATI-1GT201-F1X-825-Intercooled-Cog-Race-Kit-F-1C-F-1R-F-1X-ATI-1GT201-F1X-825.htm
http://shop.brutespeed.com/ATI-1GT201-F1X-1300-Intercooled-Cog-Race-Kit-F-1C-F-1R-F-1X-ATI-1GT201-F1X-1300.htm
Instant Phone Order Discounts!
Call us for Large Discounts on
ATI Procharger Systems.
Please remember that the prices on our site are the Procharger Minimum Advertised Prices
Call 260 672-2076
Martin718
03-03-2012, 07:59 AM
What is the difference between the F1R and the F1X? Both are limited to 1300hp right?
Bob@BruteSpeed
03-03-2012, 08:27 AM
The F-1X shares the same design strategy and high efficiency of the new F-3 series superchargers, with the following specifications:
F-1X
Base HP Range of NA Engine: 375-550 HP
Maximum Supercharged HP Rating: 1,300 HP
Maximum Airflow: 2,000 cfm
Maximum Boost: 38 psi
Volute diameter: 10.5”
Inlet Diameter: 5 inches
Outlet Diameter: 3.5 inches
Maximum Impeller RPM: 72,000
Internal Step-up Ratio: 5.40:1
Self-Contained Oiling: Yes
Reverse Rotation Available: Yes
F-1R
Volute diameter: 9.75”
Inlet Diameter: 4 inches
Outlet Diameter: 3 inches
Maximum Impeller RPM: 68,000
I'll suspect everyone will be finding the new F-1X ends up making more boost and more power than the F-1R. The inlet air temps should be cooler with the F-1X when compared to the F-1R. Bob
Martin718
03-03-2012, 08:48 AM
With those dimension I would also suspect the same fit up and clearance issues of the F2 then, the size of the F1X is the same as the F2 then if I'm not mistaken and if they are saying they have bracketry to fit a F1X which if it in fact is the same size as the F2 I would run the F2 since it's hp levels are largely greater than the F1R/F1X
Bob@BruteSpeed
03-04-2012, 06:52 AM
You are correct, you could go with the F-2. Bob
Martin718
03-04-2012, 12:28 PM
So are you saying they now have the correct brackets to put an F2 on the 5th gens?
Bob@BruteSpeed
03-08-2012, 06:55 AM
The bracket will work, but the inner fender well will need some trimming and the inlet and outlet will need couplers added that I will supply. I'm trying to find out exactly what interferes, when I find out I'll post it here. Thanks. Bob
Martin718
03-08-2012, 08:14 PM
You can just send me one and I'll install it, make the fixes and send the modifications too you!! ;)
Bob@BruteSpeed
03-09-2012, 06:41 AM
That would be a great deal for one of us! :burn: Bob
Martin718
04-23-2012, 09:21 AM
What's the update on the F1-X or F-2 on the 5th gen??looking to make a move very soon
Bob@BruteSpeed
05-08-2012, 05:48 AM
There is a thread on Camaro5 with a pic where an F-1X is being used.
Thanks. Bob
