Drag Racing Tech - Lightweight battery
John Deere racer
03-03-2012, 09:52 AM
Where can I get one
And how much weight savings?
Thanks
John02SS
03-03-2012, 02:21 PM
I ran a Braille battery for a while. It was like 13.5 lbs and did really well with the 347 as long as I didn't run the fans or bottle heater ANY without the car running. After putting the 427 in the car it just didn't want to crank it. It would slow roll it 2-3 times and fire. Always worried me and I went back to the Optima Redtop. I'll just eat that 16 extra lbs and run my bottle heater at will. :D
clint195
03-03-2012, 02:35 PM
I also had a 11 lb braille and it didnt do so well in the 08 z06. Had to end up going with a stock battery. Put the braille in my dd and still works fine.
Gilbert@Ace Racing
03-03-2012, 04:22 PM
Interesting... we ran a Braille 16v unit in a Top Sportsman car early last year and had issues with the N2O firing. We found it easy to charge, but it was lousy at discharging.
g
ATVracr
03-03-2012, 04:50 PM
Powercell technology.... 12 and 16v
John Deere racer
03-03-2012, 05:47 PM
Thanks
How much lighter?
studderin
03-03-2012, 06:42 PM
odessy PC680 think there 12# about $120
mrdragster1970
03-03-2012, 10:29 PM
They go all the way down to 5lbs.
I looked at a couple last year and was probably going to change this winter.
I was over weight last year, so it was worth all the money, they are not cheap.
ATVracr
03-04-2012, 08:03 AM
Thanks
How much lighter?
9lbs and you can use any charger you already have or alternator.
Firehawk441
03-04-2012, 08:43 AM
I was told to only use a trickle charger with my battery other then the alternator. Have you used a regular charger with yours without any issues?
joelster
03-04-2012, 08:52 AM
Odyssey PC680. Mounted up front it saves around 20lbs over the stocker (35ish for stock). I've had mine for 4 years now, and it needs to be replaced. I've run it 100% dead at least 20 times, so i'm sure that had a lot to do with killing it. I had a small battery draw that took me a while to diagnose. No complaints, it cranks over my bigger motor just fine and I don't run a lot of accessories.
John Deere racer
03-04-2012, 09:01 AM
Will the stock cables screw into the battery?
NHRAFORMULA00
03-04-2012, 09:57 AM
You need an adapter for the odessey
studderin
03-04-2012, 10:05 AM
ya, If you Lay it on its side. The battery is lower, on its side then the stop one. and re do the loom clips across the fans, to loop the pos. a little. You need the 3/8- the metric brass fittings for the stock cables to work. And you have to make a new hold down strap, I have some pics in my build thread how I did it with the stock coolant bottle still.
Ive been telling newera to make a new smaller lighter coolant bottle, that has a battery tray built in for the PC6800. I nice bolt in setup, it would save 20-25pounds. I'm hoping to make a nice setup soon.
The lithium batteries I hear are really nice for guys that have them for max effort race cars. But as a heads up, their $$$$$$ $500 $700+
TurboStangJON
03-04-2012, 11:37 AM
I ran a PC680 in the factory location for a little while without any issues.
Spoolin_Notch
03-04-2012, 04:48 PM
I use the lithiumpro.com L545-16A 4.44lbs
TurboStangJON
03-04-2012, 06:21 PM
It's lithiumpros.com for people who want to look at some nice batteries. However, looking at the L545 it's a 16V which won't work for most people and it's $1051. I want one of their batteries but it's last on the list.
Spoolin_Notch
03-04-2012, 09:13 PM
I've had nothing but good luck with them. Thanks for fixing the link
TurboStangJON
03-04-2012, 09:33 PM
No problem! I have been drooling over those batteries for a while!
lumina_cr8
05-12-2012, 08:24 AM
I'm using lithium pros C680 daily use with all the Accessories
:drive:: since 10/JAN/2012
Camaro 99 ls1 , It's save me 28 lbs !! same or more than what the an after market k-member will save
stock battery was 32
c680 just 4 lbs!!
Pony Exp.305
05-12-2012, 08:36 AM
I use D.U.I. (Davis Unified Ignition) battery and works good..#~13
http://www.performancedistributors.com
4bangermustang
05-12-2012, 05:14 PM
RB Batteries
talked to them at a recent local event. They mostly do motorcycle batt's.
will be trying one soon in a car. weights under 4 pounds.
gillbot
05-12-2012, 05:29 PM
I run a Deka powersports battery, been in the car for a few years and no problems whatsoever.
studderin
05-12-2012, 08:18 PM
car started right up this year with the oddesy PC680. Put a jumper box on it to crank it to prime oil for a while, but hooked the coils up. fired right up. And it was sitting all winter with the battery installed. No idea why some guys stay they didnt last long?
11SECSS
05-12-2012, 09:53 PM
I also run the oddesy with no problems,bought from http://www.batteriesplus.com/product_search/28965-Odyssey-Sealed-Motorcycle-Powersport-Battery-PC680.aspx
Rob94hawk
11-20-2012, 05:14 AM
I'm guessing none of these can be used in a daily driver correct?
Pro Stock John
11-20-2012, 10:03 PM
I'm thinking about a 17 or 21 lb Braille for my 4170 raceweight 5th gen.
DopeFedZ
11-20-2012, 10:15 PM
I use this one. Deka etx18l you can get it from advanced auto parts for under $100. Can be daily driven.
http://img.photobucket.com/albums/v225/9secZ28/Formula/CIMG0153.jpg
Pro Stock John
11-21-2012, 02:30 PM
I was thinking on that one, this concerned me:
CCA: 300
Braille, CCA 475: http://www.tirerack.com/accessories/detail.jsp?ID=32
4bangermustang
11-21-2012, 03:07 PM
I plan to one of theirs. They do a lot of nike stuff.
Weights like 1.5 pounds.
http://www.rbbatteries.com/car-batteries.html
I talked to him at the last kots about testing one on one of our high comp cars.
Brian
DopeFedZ
11-21-2012, 03:17 PM
Specs i seen show 340 cca. Either way it starts up everytime and handles all my nitrous shit. Buddy runs the same one on procharged c5 and another on a c6 never any issues.
4bangermustang
11-21-2012, 03:22 PM
I ised to have a danabatt?? The one with a bat on it. Left me hanging more then once. That was when i was daily driving it.
Brian
jt_2002_ta
12-06-2012, 07:55 PM
You need an adapter for the odessey what kind of adapter do u need?
DopeFedZ
12-07-2012, 01:55 AM
http://www.summitracing.com/parts/ody-3217-0006/media/images
LS-ALTERED
12-08-2012, 09:51 AM
I use a BRAILLE MICRO-LITE LITHIUM BATTERY ML14C.
Starts my 15:1 468ci engine no worries and only weighs 4 lb.
