Gen 5 Camaro External Bolt-On Tech - K&n cai
Midnight00SS
03-03-2012, 02:55 PM
Wut do u guys think of these systems? fitment wise or performance wise?
UltraZLS1
03-03-2012, 06:56 PM
Search camaro5...they talk about CAI's to death on their lol.
From what I think I remember they are not anything special and might be a bit behind the curve.
Cold Air Inductions CAI with ADM scoop is very good and one of the most popular. The latest jannetty independent dyno testing showed an 18rwhp increase with no tune with cold air inductions cai and adm scoop. 14rwhp without the scoop.
The Halltech is arguably a bit better with heat soak due to a plastic tube compared to metal with the cold air inductions. It made good power on the tests as well. Like I said...do some looking on C5.
Midnight00SS
03-03-2012, 10:30 PM
ok cool, well the K&N has a plastic tube like the Halltech as well
wise690
03-15-2012, 12:53 PM
The Halltech has a larger inlet tube, and a massive filter as well. The K&N is the same simple design, but the tube and filter are much smaller by comparison, therefore moving less air. It is still superior to the stock airbox and paper filter, just not one of the top performing intakes. A few other options to consider are, Roto-Fab, Vararam, and ADM.
Midnight00SS
03-15-2012, 10:38 PM
does it make that much of a difference in hp between the two?
wise690
03-16-2012, 04:32 PM
Honestly, proabably not. However, if your trying to squeeze out as much power as possible and don't mind paying extra, the more expensive intakes are worth looking at. Absolutely nothing wrong with K&N, other than a little too much oil on the filter element from the factory.
Like Ultra said, If you have the time, just check out Camaro5. Not the best forum for technical topics, but there are several detailed comparisons and dyno charts with no bias towards any particular brand.
Midnight00SS
03-16-2012, 11:15 PM
ok cool, i think im probably just gonna Halltech it
No Hope
03-17-2012, 02:17 AM
Halltech is definitely your best option out of those two. Roto Fab is top notch also.
Stay away from any air intake with a Aluminum coated tube or any metal tube. Heat soak will be a problem with them.
Midnight00SS
03-17-2012, 09:32 AM
yea i like the plastic, so how many mm is the stock throttle body?? and wut size inlet is the Halltech and the K&N??
No Hope
03-17-2012, 10:42 AM
Stock TB is 90mm
Halltech is made for it. I don't know about the K&N
Midnight00SS
03-17-2012, 06:14 PM
Stock TB is 90mm
Thats cool cause someone said the Halltech is an 102mm opening?
JHart
04-05-2012, 11:39 PM
i have the k&n, fit is perfect and the sound is great. butt dyno is whatever, an intakes an intake to me.
Jwright41
04-06-2012, 10:49 AM
From what I have read on here, Heat Soak only occurs when you are at a dead stop so either option would work for you.
Midnight00SS
04-10-2012, 07:05 PM
yea went with the halltech
Medic/Z28
04-11-2012, 09:20 PM
I agree with jhart. I went with K&N too in December.
Pro Stock John
04-15-2012, 12:37 AM
I'm mostly interested in before/after track results. My CAI in my TBSS dropped the truck from 13.84@99 to 13.73@101, that was pretty solid. I'd like to see similar info on the 5th gens since I just got one.
