View Full Version : Satin Black Engine Bay on a Budget?
Wnts2Go10O
03-03-2012, 07:37 PM
wht kind of decent paint/clear is out there in small quantities to do the engine bay?
through reading, im going to stay away from the duplicolor stuff. so the question is what would b a decent paint to use and how much does it usually take to do the engine bay(using a 2k paint btw).
thanks for the help.
FOSTER21
03-04-2012, 09:53 PM
If you want dull finish John Deere blitz black is the best you can buy!
wildbillSS
03-04-2012, 11:22 PM
Check out Eastwood they have an under hood 2k paint kit. Very easy product to mix and spray. I think it's around 60 bucks
Wnts2Go10O
03-05-2012, 02:14 PM
i want a dull-ish finish but not flat.
Azar_Hawke
03-05-2012, 02:20 PM
What about plastidip? Though maybe that is too flat for your liking.
Wnts2Go10O
03-05-2012, 03:54 PM
too easy to take off, especially with the environment inside the engine bay
22lambo
03-06-2012, 08:45 PM
http://www.tcpglobal.com/RestorationShop/rspcolors.aspx
You can buy a quart which is pretty cheap. I have painted a few cars with their products and they make awesome stuff
Wnts2Go10O
03-07-2012, 03:04 PM
if only the "hot rod satin black" wasnt discontinued :lol:
jet black with a matte clear? or were you suggesting the satin chassis black
also, what would a satin or matte look like with a gloss/semi gloss clear?
22lambo
03-07-2012, 05:13 PM
Try this, its the same stuff only under a different name
http://www.tcpglobal.com/kustomshop/HRF201.aspx
Wnts2Go10O
03-07-2012, 05:26 PM
will that stuff be gtg for an engine bay with all the heat, grime, etc?
22lambo
03-07-2012, 08:40 PM
Personally I have never used it under those conditions but if you do all your prep work right it shouldn't be a problem. I have seen lots of people paint their engine bays with normal auto paint without any problems.
barryp
03-09-2012, 05:46 AM
I got eastwoods 2k ceramic chassis satin black kit that came with their primer as well. I love this stuff!!! I had used por15 in the past and that stuff is junk imo.
It was easy to use--I didn't even thin it and shot with a 1.8 tip. Let me know if you have any questions.
PhantomR/T
03-09-2012, 01:13 PM
i used SEM hot rod Black for mine.
v7guy
03-15-2012, 12:46 PM
I used some duplicolor black with some satin clear. It's actually held up pretty good. Had it painted for about 10 yrs
