E-38 ECM and LY6 people
Old 03-04-2012, 10:13 AM
hicksport's Avatar
Default E-38 ECM and LY6 people
I'll start by saying thanks for any input that anyone gives to this thread.
I'm running an LY6 with a modified harness with the E38 ECM. I cannot get a tach signal from it? Everything is set correctly with HP tuners in the program and I think I have the correct pin from the ECM connected? The motor is in a 1992 Camaro, I'm using the factory tach, I've tried an aftermarket one as well.
Once again thanks for any help.
Old 03-06-2012, 09:01 PM
85MikeTPI's Avatar
How do you have it setup?
http://www.hptuners.com/forum/showthread.php?t=36611
Old 03-07-2012, 07:08 AM
LS1Tech Sponsor
psiconversion's Avatar
Did you set HP Tuners to read 'Crank' and the hi and low to 15? What Tachometer are you using?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 03-07-2012, 01:15 PM
svaras's Avatar
Jon
PSI
This.-
Old 03-08-2012, 12:40 PM
hicksport's Avatar
Im using the stock tach (1992 camaro), I have hp tuners set to crank and 15. Im not sure which pin on the ecm I used I think its pin 49 on c1.
Old 03-08-2012, 02:51 PM
hicksport's Avatar
I added a pin to J1 or X1 connector in socket 48.
Old 03-08-2012, 08:22 PM
LS1Tech Sponsor
Black connector pin 48.
Jon
PSI
__________________
Ebay Store
Old 03-23-2012, 02:03 PM
bhop42's Avatar
You're going to have to add 12 volts as well as a resistor(dont remember what size) to actually power the tach.
Old 03-23-2012, 09:26 PM
hicksport's Avatar
Ive tried the pull up resistor, with no luck.......
Quick Reply: E-38 ECM and LY6 people
