crossover / merge pipe
Old 03-04-2012, 02:24 PM
Dracer91's Avatar
Default crossover / merge pipe
Is a 2'' crossover to small for a 5.3 with 317 heads? Im running a pt76gts and flipped manifolds. I'm not looking to rev it past 6500. Im looking to keep the speed up all the way to the turbine. I think 2" would work but maybe 2.25" would be better. Tell me what you think.
Old 03-04-2012, 07:47 PM
Moter's Avatar
2 inch will work fine.
Old 03-04-2012, 08:24 PM
dschmittie1's Avatar
2 inch would be good for a 5.3
Old 03-04-2012, 09:46 PM
Dracer91's Avatar
Thanks for the replies. Anybody ever try this? It seems like the norm is 2.5" on everything. I have been doing alot of searching and reading on this. It seems like lots of people talk about using 2'' and 2.25''. I only see a few guys running 2.25" , most use 2.5'', never see 2". I think it will be awsome, quick spool and as long as it holds out to 6500 I will be running 9's. If "phill99vette" is out there I would like to see what he thinks. I learned a ton of stuff from his posts.
