Turn signal flasher
Old 03-22-2004, 01:15 PM
FL THRTL's Avatar
Default Turn signal flasher
I need to replace my turn signal flasher and was wondering if anyone here had any helpful tips. I'm not exaactly sure where the module is located, allthough i know it is somewhere under the dash. any help would be much appreciated, as i pulled the boards off the underneath of my dash on the drivers side, and i still couldnt find the module... thanks
Old 03-22-2004, 05:05 PM
Copy & Paste Moderator
VIP1's Avatar
Its round and silver. Remove the kick panel under the steering wheel. There are two flasers, one for turn signal and one for hazards.
--VIP1
Old 03-24-2004, 07:49 AM
Ungrounded Moderator
WhiteBird00's Avatar
The turn signal flasher is the one clipped to the right of the opening when you take off the knee panel under the steering column. The hazard flasher is on the left.
Old 03-24-2004, 03:27 PM
FL THRTL's Avatar
Thanks guys, when I looked the first time I expected to see the actual modual hanging, however, once I found it, it only took a sec.
