Has anyone ever fixed a BCM?
Old 03-04-2012, 11:56 PM
Shackleford's Avatar
Default Has anyone ever fixed a BCM?
Mine randomly cuts out the head unit, windows, etc. I've been told it's a loose solder connection in the BCM.
Old 03-04-2012, 11:59 PM
ANTICOP RAM AIR's Avatar
I have but I have considerable experience with that sort of thing.. you have a loose pin... its an easy fix..
https://ls1tech.com/forums/general-l...ems-fix-7.html
Old 03-05-2012, 12:08 AM
Excellent. Thanks for the info.
Old 03-05-2012, 12:53 AM
Super-Bat's Avatar
Here's a good write up on it:
How To Fix Intermittent Windows, Radio and Locks
Old 03-05-2012, 05:50 PM
Originally Posted by Super-Bat
Great. Thanks. I'll get an electronics buddy to do the soldering work, but I'll probably take off the panels and such beforehand.
Old 03-05-2012, 06:01 PM
anthonyg956's Avatar
Took me about 7 min.'s to remove the unit from my car last week... Shouldn't be too much of a problem... & if you do decide to replace... You might want to check them out online... If you do go that route, just make sure you buy it "NEW"... it may save some time and hassle (such as doing a VATS bypass..) Just my 2 cents...
Old 03-05-2012, 10:41 PM
slayer_taunu's Avatar
i did this repair on my camaro using the writeup from camarozone. the hardest part was just getting it out. it LOOKS like you can get it out with just removing the lower dash panel... but you really have to remove the kick panels too.
while i had the BCM apart, i also disabled my automatic headlights.
Old 03-06-2012, 09:00 PM
SnIpEz's Avatar
I did it about a year and a half ago, just for ***** and giggles. A friend of mine was having trouble removing his BCM after removing the panels, so I walked over to my car and had it out and soldered, and by that time he still hadn't gotten it out lol. Took me about 15 minutes, including time to heat up the soldering iron.
