Sponsored by: DashLynx
hids
Old 03-05-2012, 09:06 AM
BadCompany VP WS6's Avatar
Default hids
So I installed the HIDS from Xentec this weekend and the install went smooth and they look great. One problem I have encountered is that when I unlock the car with the FOB, the head lights pop up and then back down. They did not do this before the HID install. Also, when I turn on JUST the fogs, the head lights pop up and stay up but the lights are not on...until I flip the switch to the on position.
Has anyone encountered this? What's the fix?
Old 03-05-2012, 10:03 AM
PontiacFan's Avatar
https://ls1tech.com/forums/pontiac-f...s-go-here.html
Sounds like you should have changed the gears while you had them all apart.
Old 03-05-2012, 10:15 AM
Pure coincidence that it happened when I installed the HID's? I have never had this happen prior to the install.
Old 03-05-2012, 12:39 PM
tvg001's Avatar
check your alarm programming setting this might help
http://www.ls1.com/forums/f50/alarm-...changes-18690/
if this dont work check your gears if there strip just flip em 180 and they will work aslong as they havent done this to them
Quick Reply: hids
