370, which heads
Old 03-05-2012, 09:12 AM
RoidedSS's Avatar
Default 370, which heads
I'm on my phone so mods, please put this in the correct place if this is wrong. I'm planning on a 370 lq9 build which will eventually get a 4 inch stroke to make it a 408 once the funds are there. I'm not going for a max effort build so I was wondering the pros and cons of either getting 243's or some ls3/l92 heads. The cam will be purchased after the heads are bought. All thoughts or opinions are welcome
Old 03-06-2012, 03:25 PM
RoidedSS's Avatar
no suggestions or thoughts?
Old 03-06-2012, 03:31 PM
INIT2WIN's Avatar
I'm running a stock ci LQ9 with SDPC ported LS3 heads in my car. My car made 463rwhp and 430rwtq with a futral specd cam in it. It feels great on the street and pulls hard all the way to 6500rpms!
Old 03-06-2012, 06:50 PM
RoidedSS's Avatar
can i ask the specs on the cam or pm me the specs? i plan to also get a cam spec'd from them
Old 03-06-2012, 08:10 PM
INIT2WIN's Avatar
Its a 228/242 .605 .595 lift on a 112+4 LSA
Old 03-06-2012, 09:04 PM
Go On 3's Avatar
i have TEA 243 stage 2 heads on my 370, small 228/230 cam and its a strong runner. I will have new dyno numbers by the end of the month but it should be in the 440hp 430tq range through an auto.
Old 03-06-2012, 10:11 PM
garygnu's Avatar
I saw a article in gm-hitech about l92 heads making good power unported .I think you mite find some at SDPC for $375 each.talk to Pat-G for a custom cam.
Old 03-06-2012, 11:14 PM
RoidedSS's Avatar
I will have the heads done up at AI regardless of which set up I go with. And I will most likely have futral spec me a cam or have Pat G. I just heard it takes Pat a while since he's so busy which is definitely understandable. Go On 3 have, keep me updated please. and the l92/ls3 castings are pretty cheap from what I have seen. I just wish I knew more as to why they need just a wide split for the duration. I appreciate the input so far. Do either of you guys have track times?
Old 03-07-2012, 05:20 AM
INIT2WIN's Avatar
I have been to the track with some bald nittos, and poor track prep. My car is a full weight (3600lbs) M6 car with 4.10 gears. It has ran a best of 11.92@122 with a poor 1.9 60'! There is a lot left in it if i can get it to hook! I'm thinking it should go 11.5 or better with new drag radials and better track prep!
Old 03-07-2012, 09:20 AM
jmm98LS1's Avatar
I have TSP 5.3 heads on my 370ci, makes 500hp/450tq at the wheels through a heavy drive train.
Old 03-07-2012, 10:27 AM
RoidedSS's Avatar
Any idea what compression your sitting at?
Nvm, I see your sig now. I was on my phone
Old 03-07-2012, 03:01 PM
Transamthunder's Avatar
Love how that camaro sounds in the vid Jmm...very nice.
Old 03-07-2012, 03:05 PM
INIT2WIN's Avatar
This is a idle video of my car is anyone is interested in hearing it.
http://www.youtube.com/watch?v=27qxR...e_gdata_player
Old 03-09-2012, 09:53 AM
RoidedSS's Avatar
man, that sounds sweet. the 370 seems to really eat that cam up and it doesn't lope too crazily like some cams do. Thanks guys for the input. I should have new parts flowing in this summer.
Old 03-10-2012, 12:11 AM
MASS seller approved
smok'nZ's Avatar
tfs 235's or afr 230's if you have the cash if not cnc'd L92's by TEA then prc or tsp TEA FTW or mamo 230's
Old 03-10-2012, 09:22 AM
RoidedSS's Avatar
smok'nz, i'm looking at the L92's, but do you have any idea of TEA vs AI flow numbers or results?
Old 03-10-2012, 09:51 AM
COPO9560's Avatar
If you don't plan FI the AI L92/LS3 option will provide good power for the value. They might be able to put you together a head/cam combination as well to meet your needs.
Old 03-11-2012, 12:43 AM
RoidedSS's Avatar
what if forced induction was a thought down the road. I've always tinkered with the thought of a turbo, but this build will stay as is for 2 or 3 years since I'm heading to grad school
Quick Reply: 370, which heads
