Am I out of injector?
Old 03-05-2012, 09:48 AM
mikh338's Avatar
Default Am I out of injector?
so i found out with my setup I am still running stock fuel injectos. they are 28lb ls6 injectors. car was tuned with these and runs fantastic. i have a few friends that are very concerned that I am beyone maxing out my injectors and am going to hurt my motor. i dont understand as it has been this way for 3 years with no problems. they suggested going to 42lb injectors. I am looking to upgrade when I do different heads and intake manifold as I dont want to have to keep doing a retune after each different parts are installed. i dont hve tuning info on the car, as it was done in Kentucky at Bluecat tuning which from everything i have read is a excellent shop. I just posted up on KYhorsepower to try to get ahold of Phillip so I can get tune specifics. Just want to get peoples opinions.
Old 03-05-2012, 10:20 AM
Big Al's Avatar
What you need to do is find out if your friends are right. Just take it out on the highway and let it rip. Keep it wide open for a while in whatever gear gets the RPM around 5,500. Then pull over and pull a few plugs and see what they look like. Look at the shell, not the center electrode as you're not looking at plug temperature (yet) you just want to see what the combustion chamber looks like.
A wide band O2 sensor would make it easier.
That's about as good as I can do with no car information.
Al 95 Z28
Old 03-05-2012, 10:38 AM
smokeshow72's Avatar
Seems like a lot of cam for 28s, but three years is a long time; I don't think I'd panic, but I'd suggest some junkyard GM 42s out of a supercharged Buick / Pontiac / Chevy 3800 6cyl wreck.
C
Old 03-05-2012, 10:58 AM
chasgiv3's Avatar
OK some confusing information here. You say these are stock injectors then you say they are LS6 injectors. Not familiar with what changes happened in what year to the LS1 so I can't speak to whether an LS1 ever came with an LS6 injector. I assume so from your statement. The LS6 injectors were rates at 28.6 @58PSI. So theoretically at 90% duty cycle your motor should be able to produce around 475 crank HP. Or say 415RWHP.
That's a pretty big cam in there with pretty good overlap. I would hazard to guess that you're probably fine with what you have in there. And remember most folks tell you that you should always go to only 80% duty cycle on the injectors while I quoted 90%. The reason I went that high is due to the fact that I've been there and have run at 90% without issues for years.
Now I assume you had the car dyno tuned? If so get the graph and look at your RWHP. It should also have a A/F ratio number in there also. If you don't have dyno information then I recommend you get a dyno reading. Reading the plugs will work but when I've seen it done it's fresh set of plugs, make a run, shut it off right after the lights, coast to a stop after the turn off and have it towed back to the paddock to pull the plugs and read them.
For $190 bucks you can buy a wideband but you'll have to get a bung welded on to your exhaust. For 100 bucks you should be able to get a dyno graph done on your car with ther WB data on it from a full service speed shop.
Old 03-05-2012, 12:14 PM
mikh338's Avatar
well the ls1\ls6 injectors for 01-02 are the same(as I have been told many times now)and yes 28lbs. my car was tuned in KY at bluecat tuning by Phill who everyone says is "the man". I have been trying to get in contact with him to get all tuning info etc...All I really know is that the car is in a SD tune. The car was dynoed at 440whp but is more like 470whp since their dyno reads 7-8% low. So yes I am deff beyond the stock injectors if you say they should be good for 415whp. And yes I am about to buy a wideband, and with my tune I have 0 o2 sensors hooked up so I will just take the bolt out of the header bung that is being plugged and hook it up to that. I wouldnt mind always having that info in the car at all times. I am changing plugs and wires this week so I will look at them when I do that.
Old 03-05-2012, 12:25 PM
mikh338's Avatar
my only fuel mod on the car is a Deatsch Werks fuel pump which flows 300+lph
Old 03-05-2012, 04:23 PM
Old Geezer's Avatar
1 run with a scan tool and the correct pids, will tell you all you need to know.
Read the inj dc. Done deal. They are ok, or they are not..
Old 03-06-2012, 03:27 PM
ZL1Killa's Avatar
go out on the highway or road with a scanning program or someone with datalogging software and log your injector duty cycle. if it is above 80% I would recommend an upgrade.
from your mods list, I would have to bet you are beyond 80%.... 42# is likely overkill for your setup...maybe 36# would be fine
Old 03-06-2012, 05:25 PM
mikh338's Avatar
well as far as my setup goes, i will be putting 5.3 stage 2.5 heads on, fast setup of some kind and most likely going to true duals. thats it for now. So i would rather have a little more injector then I need so in the future if more mods are done I wont have to buy again. Tune will take care of that.
Old 03-08-2012, 08:39 AM
ZL1Killa's Avatar
the stock injectors don't handle much above a few bolt-ons honestly.
Old 03-08-2012, 04:14 PM
2QUIK4U's Avatar
Not true. I have run several cam only, and heads/cam cars on stock injectors with no issues.
Old 03-08-2012, 10:02 PM
joecar's Avatar
^^^ This +1.
Old 03-09-2012, 07:46 AM
ZL1Killa's Avatar
cam only - i consider this a bolt in (on)
heads cam cars - what heads?... it always depends
sure, a ls1 car swapped to a custom cam and ls6 heads, yeh that will work fine.
If you are going to start doing mods and you know you will be doing more, why not provide enough fuel for at least 15% future power, as the injectors and the fuel sizing won't care and the tune in the car won't care. You can run 42# injectors on a stock car with absolutely no idle problems or any problems of the sort.
I know you are likely just noting a point about it being doable, and there is such a thing as overkill or going overboard, but c'mon we can go around and around about this. In general, if you are looking at modifications its always good to keep things in perspective and know where you are with regards to fuel consumption and your engine.
take 26# per hour and convert it to liters per hour
your fuel pump is rated liters per hour
BAM. solution
take 36# per hour and convert to liters per hour
find a fuel pump that is above this rating
BAM. solution
Old 03-09-2012, 09:22 AM
mikh338's Avatar
BAM. solution
BAM. solution
how do you convert that? my fuel pump is rated at 300+lph.
Old 03-09-2012, 12:10 PM
ZL1Killa's Avatar
First look here: Fuel Sticky
Download UConeer conversion program.
1 Liter IS 0.2642 gallons
so 1 Liter per hour is 0.2642 gallons per hour
A Fuel pump rated 300 Liters Per Hour can handle:
300 LPH
79.26 GPH
1 gallon of gas is 6.07LB OR
1 liter of gas is 1.604LB
300 Liter ......... 1.604 LB ...... 481.2 LB
1 hr ........... x 1 liter .......... = 1 hr
(* cross multiplication, liters cancel; you are left with LB/hr)
Divide by 8 injectors
481.2/8 = 60.15 LB/hr injectors at a single 300 LPH pump
also keep in mind everything is NOT perfect and won't give you exactly what these numbers say, I'm in no way responsible if you hook this up and it doesn't keep your fuel supplied, hahaha.
it is also good to see or know the fuel pump curve for each fuel pump you use, this tells the story.
Old 03-09-2012, 09:08 PM
mikh338's Avatar
so today my friend noticed my injectors were not stock. after we actually looked at them they are ford red tops? does anyone know what size these could be? i keep finding 30lb but ppl are saying they actually flow 36lbs?
Old 03-12-2012, 11:29 AM
ZL1Killa's Avatar
****IF they are 30 LB/hr, then they are rated 30LB/hr @ 43.5psi (3 bar)
our fuel pressure is 58psi (4 bar)
Sqrt(58/43.5) = 1.1547% larger value
multiply the 30LB * 1.1547 and that is your new injector value at our 58psi
which is: 34.64 LB / Hr
Old 03-13-2012, 01:25 PM
mikh338's Avatar
ok great. what the hp limit on an injector this size?
Old 03-14-2012, 12:08 PM
ZL1Killa's Avatar
naturally aspirated ... probably right 480~500 or so.
check out www.rceng.com and their Technical Sizing link at the left, then scroll all the way down to the bottom 520 engine HP makes it about 35LB/hr injector...so at the wheels about 490 or so
Old 03-14-2012, 03:31 PM
mikh338's Avatar
awesome, great info again thanks!!
