Bad bucking
FALSE AS ****
i have a COMP XE-R 236 238 .601 .605 112+4 LSA
i had some bad bucking from 1k to the 1.5k RPMs also
i took it back to my tuner and he fixed it i still have a little bit of bucking but nothing like i had before ..
so i would ask to look at the tune again .. they should try to get it right for you
your cam should not have much buck in it at all i have a bigger cam then that and the only time mine will buck is it u try to let it idle going through a parking lot anything above an idle and my car will not buck i would say your problem is in the tune because my car use to do what you are descibing when it was about halfway tuned with a good tune it should drive near stock or at least mine does but i have countless hours in getting my tune perfect
