Gears & Axles - moser 12 bolt whine?
View Full Version : moser 12 bolt whine?
white99ta!!
03-05-2012, 08:25 PM
Hey guys, ive been looking for a new rear and I found out close to me. moser 12bolt with maybe 2000 miles, detroit true trac diff,3.90 motive gear,30 spline, professionally shimed and wear pattern is perfect but till has a whine. The guy selling it keep reassuring me nothing is wrong with it but it still whines at 45. Is this a normal thing for moser 12 bolts or should I stay away? Thanks in advance
96lt4c4
03-06-2012, 08:00 AM
Depends on a lot of things, a lot of aftermarket rearends and gears make noise. Take a picture of the pattern if you can.
Carter01
03-06-2012, 08:13 AM
Most 12 bolts do whine after hard launches. The 9 inch is less prone to whining due to the better pinion support. It's probably fine but the whine is there to stay unless you replace the gears.
hiltsy855
03-06-2012, 10:20 AM
..... but the whine is there to stay unless you replace the gears. Does it go away with new gears? Assume it will come back again after another hard launch.
01ssreda4
03-06-2012, 12:17 PM
Completely normal IMO. Go Strange for 12 bolts :nod:
ZexGX
07-17-2012, 11:50 AM
So Strange 12 bolts don't whine after hard launches? Please explain the reasoning behind this...
Ethan[ws6]
07-17-2012, 09:44 PM
I have a moser 12 bolt that I beat the shit out of, and I have 3 friends that also have them and also beat the shit out of them and none of our rear ends whine. I have heard of people complaining that moser rear ends whine, but I honestly think it's because of improper setup. I think they just get it "close enough" but still in spec and send it out. I had to take mine apart and set it up properly when I bought it. Not trying to say that I'm better than moser by any means, maybe I just care more? lol. Either way, after I set it up there was no whine and still isn't.
Macs98Z
07-18-2012, 11:17 AM
;16529191']I have a moser 12 bolt that I beat the shit out of, and I have 3 friends that also have them and also beat the shit out of them and none of our rear ends whine. I have heard of people complaining that moser rear ends whine, but I honestly think it's because of improper setup. I think they just get it "close enough" but still in spec and send it out. I had to take mine apart and set it up properly when I bought it. Not trying to say that I'm better than moser by any means, maybe I just care more? lol. Either way, after I set it up there was no whine and still isn't.
Ethan, are all three of your friends M6 cars as well?
Ethan[ws6]
07-20-2012, 07:17 AM
Yes, every one of them.
ramairetransam
07-20-2012, 07:53 AM
have them put slicks on an dump the clutch at 5k they will all whine .
Macs98Z
07-20-2012, 08:25 AM
;16537828']Yes, every one of them.
This is what I am wondering as well. Ethan, have you all taken your cars to the track with a good set of sticky tires and done some runs dumping the clutch from a decent rpm?
I know a lot of people experience whine with their 12 bolts, and most say it happens after a few track runs, but then there are others who say theirs are fine. You mentioned setting your rear end up properly after buying. I'm curious to see if this might be the reason 12 bolts whine. If you and your friends are doing the same thing everyone else has done (hard abuse, drag strip use on sticky tires) and still don't have whine, you may have found the issue with 12 bolt whine.
Do you and your friends take your cars to the strip with sticky tires? Have your friends also set up their rears properly after buying them?
Coonass350
07-20-2012, 09:16 AM
^^ would also like to know this as well..
01ssreda4
07-21-2012, 08:58 AM
Center section casting differences and I believe a better overall product then a Moser....since you asked.
Ethan[ws6]
07-21-2012, 10:22 AM
Been there done that. My car is still quiet.
One of my friends is running 10.80's in his car. He launches pretty high. I think his 2 step is set to like 5200 or something. I usually dump it around 3-3500. Seems to work best for me lol. The other friend goes to the track at least every other weekend. He only uses drag radials, so we can throw him out of this if you want :P Also, his hasn't been touched since it came from moser. Mine and the friend hitting 10's have adjusted ours.
Macs98Z
07-21-2012, 12:39 PM
;16541096']Been there done that. My car is still quiet.
Great info. Thanks for sharing that, Ethan.
camd01silv
08-03-2012, 04:44 PM
I read somewhere that a lot of times a few hard launches on a 12 bolt that uses a torque arm will cause case deformities. My 12 bolt was halfway quiet when I first bought it, but after a few hard launches, it whined pretty loud. Got it to quiet down quite a bit, but still very noticeable. Been through a couple sets of gears and it still whines. The case deformation would explain my whine. I guess some cases are better than others.
