Dyno Guesses & Bench Racing Forum - What hp will i have with my setup
juanioz28
03-05-2012, 09:23 PM
I have a 98 camaro ls1 with a lingenfelter GT2-3 cam kit 243 milled heads a bbk ssi intake long tube headers and a k&n? Do i need to change injectors?
Burken01
03-05-2012, 09:43 PM
I went with ford green top 42lb injectors with my H/C swap, seems like most people are damn near maxing out injectors with typical H/C swaps...
splitfinger09
03-05-2012, 10:35 PM
x2 green tops have been working well for me so far.
Tyrel2018
03-06-2012, 03:41 PM
you could also use the 36lb injectors out of the pontiac gtp's, they will do fine for what you have but if you ever wanna make more horse power i would say go with the green top 42lb injectors.
juanioz28
03-08-2012, 05:02 AM
Around how much horsepower should i get from this set up
Burken01
03-08-2012, 10:04 AM
well that cam is 207 / 220 .571" / .578" 118.5 lsa so it's on the smaller side as far as ls1 cams...
it would be a good Daily driver cam and very quiet, with a good tune I think you could hit 370-380 hp with it?
You might want to go a little bigger, you can go up to a 224-226 and still have stock like driveability and more power everywhere... but the cam you have will work good..
juanioz28
03-11-2012, 05:58 AM
Thats what im hoping for around 370 to 380hp
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
