Dynamometer Results & Comparisons - Advanced Induction H/C/I a4 dyno results
crazyelf
03-05-2012, 10:15 PM
Rundown of my set up:
Ai 226cc ls6 heads milled to 60cc for 11:1 compression
Ai 226/234 630/630 113
7.4 pushrods
PRC eht .675 springs w/titanium retainers
Fast 90
Fast 36lb injectors
Ls2 timing set
Ls7 lifters
TR6 plugs
Melling 10295
Amsoil air filter
Pacesetter headers
Custom ORY
GMMG
FTP 98mm lid
85mm maf
Powerbond underdrive
I did not flycut
This is through a spohn chromoly ds and Moser 12 w/3.73 and 19 wheel tire combo that literally weigh in at 64lbs a piece LOL
423/367
http://i746.photobucket.com/albums/xx102/crazyelf44/IMAG0072-1.jpg
http://i746.photobucket.com/albums/xx102/crazyelf44/IMAG0054.jpg
http://i746.photobucket.com/albums/xx102/crazyelf44/IMAG0068-1.jpg
http://youtu.be/m66MQ6Kl-7g
http://youtu.be/4wMvSXdOzzY
Besides the torque which I strongly believe is some kind of error, I am happy considering the power robbers I have. I do plan on getting a light weight wheel tire combo which the tuner says would easily put me into the 430+whp
Im more worried about track times anyways, Btw Im going to be getting a higher stall converter soon.
and now eye candy.....haha
http://i746.photobucket.com/albums/xx102/crazyelf44/22.png
http://i746.photobucket.com/albums/xx102/crazyelf44/3.jpg
Conrad
03-05-2012, 10:22 PM
Sick...can't wait till I have the $$$ to get the same combo. I'm thinking a little bit bigger cam than you, although yours sounds great thru the GMMG even untuned. Nice pictures too :hail:
Austinma62
03-05-2012, 11:35 PM
Hp seems pretty good. Im actually thinking of doing this exact setup on my t/a but im a m6. Did you do the install yourself?
Austinma62
03-05-2012, 11:36 PM
also that green goblin lookin paint is pretty damn sweet!
crazyelf
03-05-2012, 11:50 PM
Thanks guys, and yes I did the Install myself with help from a friend.
yonerhottlt1
03-06-2012, 03:13 AM
Digging the paint! That LT doesn't look to shabby either
vettenuts
03-06-2012, 04:18 AM
What was your PTV with that setup?
Mike454SS
03-06-2012, 07:37 PM
Great numbers through an auto man!!! I think the torque number looks about right, you're revving fairly high.
EVIL 6.0
03-06-2012, 07:42 PM
Nice numbers. AI does great work
SAPS
03-06-2012, 08:07 PM
What stall do you have? Was it locked for the dyno run?
reeperz28
03-06-2012, 09:15 PM
Moser 12 bolt, loose converter, heavy ass wheels, possible unlocked dyno number.. its just numbers but try and get some 1/4 times I'm in need of some redemption cause I'm in the process of getting this same kit and also have an a4. How was the seat of the pants feel ? Nice car!
Rise of the Phoenix
03-07-2012, 11:58 AM
Curious too about the Piston to Valve Clearence. 60cc is a pretty big mill for that size cam. Flycut?
redtail2426
03-07-2012, 08:01 PM
Yeah im curious as to how you got away without flycutting,so what was the ptv clearance on that
reeperz28
03-07-2012, 08:19 PM
On AI's website the heads cam kit says .600 .600 lift for that cam. That may help the ptv clearence for the 60cc. But just going off the website.
crazyelf
03-07-2012, 09:03 PM
vig 3200 stall and yes it was locked on the dyno
Car feels Very strong! I need traction to really feel it though haha
I did not fly cut, ptv is around .064/.080. Lift on the cam is actually .630 not the .600 on their site. These heads utilize stock valves which helps with ptv. The combination of ls6 light weight valves and very good valve springs should help me avoid any problems.
crazyelf
03-07-2012, 09:10 PM
BTW guys I will be going to a different dyno soon for another run. Yesterday I was told a cam only c6 z06 only put down 480/430.....low low low This was the same dyno I was on and another friend of mine with prc 5.3, fast 90 and a 231/237 cam only put down 418/350
so Im convinced this is a heart breaker dyno
Conrad
03-07-2012, 09:17 PM
Interested to see the new numbers...my car is an m6 so I'm really looking forward to buying this set up.
Rare96LT1Formula
03-08-2012, 08:01 AM
Numbers seem a tad low for such a stout combo. I was thinking more along the lines of 440-450 imho. At the end of the day though, numbers mean nothing. Run that thing at the track! Nice car man
Rise of the Phoenix
03-08-2012, 10:05 AM
Lift has nothing to do with piston to valve clearence.
SAPS
03-08-2012, 03:24 PM
Is there a way to determine a converter was locked or unlocked by simply looking at the dyno graph?
Advanced Induction
03-15-2012, 09:13 AM
Glad it has all come together! Assuming everything regarding the engine is assembled properly, no vac leaks, properly calibrated etc. then it sounds like your drive train might be burning up 20-30#'s. Either way, a good first session & now with dyno data and further data logging/tinkering you can likely refine the setup to get it to run to potential. :)
On p2v, I generally want a theoretical minimum in the .06X"+ range. A bit more than some of the grinds commonly run, but that safety margin has worked out well thus far for guys who want to just bolt things together. Since every cam is QC'd I can pick what should be a safe valve location/chamber volume for the individual setup. I can account for variances due to the tolerance range of the timing set, but not things like inordinate timing set wear, crank index, etc. which may bump actual clearances a bit in either direction. It is always best to check, and if someone wants a max effort setup then it is generally a necessity. :)
crazyelf
03-15-2012, 07:07 PM
Thank you to advanced induction, they were great at answering all my questions and setting me up with exactly what I wanted out of my car.
I will be receiving my drag wheel/tire set up soon so that I can hit the track. I'm confident that this set up has a low low 11 in it!
T.Man
03-18-2012, 11:50 AM
Sorry to say but that dyno is far from a "heart breaker". My H/C Camaro put down 450/400 the very next day after putting down 451/399 on ProDyno's dynojet. 384 stroker did 471/440 in 110* weather too. Hell, my tune only Cobalt SS running on E47 put down 311/360 :D I'd venture to say that you just don't have a dyno friendly setup (stalled auto, heavy ass wheels, geared 12 bolt). Who did your tuning? Any track runs yet?
Marc 85Z28
03-18-2012, 01:02 PM
Yes. His graph is very obviously of a locked converter. The graph is too linear at too low of an RPM to be an unlocked converter.
Those numbers are very poor all things considered.
01ssreda4
03-18-2012, 11:26 PM
Nice color :thumb:
crazyelf
03-19-2012, 04:49 PM
I've always gone to this dyno with results I expected until recently seeing a string of low numbers come off of it. Maybe weather station error? Idk but it seems its reading correctly again from looking at a few friends dyno from a couple days ago. No track results yet as I'm awaiting the arrival of my drag wheels. A few street roll races against similar power manual cars have shown me it's running very strong.
I'm also having transmission issues that need sorting out :(
Blk_Ws6
03-20-2012, 08:36 PM
:corn:
00 Freak
03-24-2012, 03:54 AM
hey crazyelf where are you getting your work done?? Im moving out to Tucson and i see your in scottsdale so not very far. I want to know how the fbody scene is out there. Im in the process of doing a turbo build on mine.
ScreaminRedZ
03-24-2012, 06:33 PM
Nice numbers, that color is great!
crazyelf
03-25-2012, 08:53 PM
I've done mostly all the work on my car myself besides the transmission building. Check out azfullthrottle.com for the local car scene. Join up and introduce yourself!
00 Freak
03-26-2012, 01:21 PM
most definitely will!!! Thanks looking forward to it
