help with bmr k-member
Old 03-22-2004, 05:38 PM
cablebandit's Avatar
Default help with bmr k-member
I have the bmr k-member..upper and lower a-arms. I notice that there is a good amount of clearance on the lower a-arm mount (front mount...not the spherical rod end). Also, the instructions say to grease the bushings...how...there is no grease fitting? The a-arms come with washers to take up clearance but the instructions only mention using them for the spherical rod end mount....and they are needed. 2 per side and they supply 4 total. Any help with the clearance on the front mount?
Old 03-24-2004, 02:19 AM
WILWAXU's Avatar
I took a look at mine tonight. I used one washer on the front side of the arms on both sides. I'm sure this varies a little from piece to piece.
