Advanced Engineering Tech - Exhaust Volume/Back Pressure Question
LS1RatRod
03-06-2012, 10:04 PM
Is it possible to run a rectangular tubing for an exhaust? If it has the same flow volume as a 3" round exhaust will it have the same type of back pressure? The reason I ask is because im lowering my car and I have custom side pipes and they have issues with scraping the ground at current height. So I figured if I lower the car 1 3/4 in the rear 2" in front I can make it back running a 2"x4" (equivalent to 3"?) rectangular tubing instead of running the 3 1/2" round side pipes.
mark21742
03-08-2012, 07:01 AM
I doubt you would see a difference in performance going to the square tubing, but I did read a good writeup a while beck about square vs round tube flow, and the same size volume round tube outflows the square tube
VodeAn
03-09-2012, 09:39 AM
Back pressure is NEVER a good thing. You gain low end torque from scavenging, a process in which after a section of gas leaves the head the vacuum behind it helps draw the next section through. I hear a lot of people say open headers is no good because their is no back pressure, this is incorrect. Open headers cause a loss of low end torque due to a lack of this scavenging effect. So the real question is how will switching to rectangular pipe effect scavenging? I would assume that you would lose some power from the exhaust gas and the vacuum behind it mixing, especially at the transition from round to square, however if you use square pipe for only the last 1/4 of your exhaust system the power loss would be negligible.
99Bluz28
03-09-2012, 04:39 PM
I believe what you want is oval tubing, correct?
mark21742
03-09-2012, 05:16 PM
I ended up crushing 3" pipe down to oval on a front wheel drive car one time to run under a flat floor for ground clearance...wasn't a performance beast though...1.7liter V4 with a wopping 78 HP
VodeAn
03-12-2012, 07:17 AM
Good idea, I completely for got about that, oval will yield better results then square. In fact I may end up using some for my 300zx, to minimize the chance of scraping before the exhaust splits in the rear.
3.4camaro
03-12-2012, 09:08 AM
As long as the hydraulic diameter is the same you should be just fine.
HD=4*Area/perimeter.
99Bluz28
03-12-2012, 02:51 PM
The only down side is Oval Mandrel Bends are rather expensive.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
