valve body
valve body
anyone replace just their valve body to see if that fixes the transmission before having to replace it?
i know its a lot of work with its location, but all the issues at least from what i'm reading all start in the valve body... TEP has an upgraded one that is suppose to fix most of the short comings.
mines starting to act up, but figure 300 dollars and a crap load of work is a little easier to swallow then 1800 and a lot of work or paying someone to do it.
I put a TEP valve body into a newly-remanufactured trans GM put in my car under warranty. I also bought the long seal kit, shift kit, and a new converter. We've put 54,000 miles on it since then, and it's been flawless.
So yes, to answer your question, you can do just a valve body, but your trans has to be trouble-free to begin with.
The TCC is also a big issue the dod constantly causes your tcc to cycle which causes unneccerry stress. The Sonnax relief valve can cure this. Bus as ls1 said its best to start these uprgrade on a flawlwess trans, if not your just delaying the inevitable. And if your under warranty you could delay it til its out of warranty and you dont want that.
but yeah i've been having issues for awhile and its seems like its getting worse every day, just started doing the rpm surge over 40 mph... i was going to do a tune up and check the maf but i'm really thinking its a trans issue.
no warranty, cars almost paid off so really dont want to go trade it in.
Not trying to be jerk or anything, but if you're not sure about where the TCC is, you probably shouldn't be tearing into your transmission on your own.
or were you referring to the clutch itself... if so my bad i wasnt aware that was the issue i thought it was more the solenoids.
your talking about the torque convert control solenoids correct? thats part of the upgrade TEP valve body, i guess technically its not part of the valve body but it does hook into it.
