bolts to put the engine together
Where can I find miscellaneous bolts to put my engine back together. I'll need some of the external bolts like, starter bolts, throttle body bolts, and I am sure others. I know I came across a website at some point that listed all the necessary bolts and their sizes but did not bookmark it.
My local Ace store does have a fair selection on metric stuff, but a little pricey. I researched what I needed, made a list and ordered from:
http://www.boltdepot.com/
Could order 1 of each if needed. Even with shipping, this saved me a bunch.
Don't know if it helps, but here's some of the part #'s I used:
Mount Bolts - ARP (ARP-130-3105)
Torque Converter Bolts - ARP (ARP-230-7305)
Flexplate Bolts - ARP (ARP-244-2901)
Bellhousing Bolts - Summit (SUM-HK-M10C40)
Water Pump Bolts - ARP (ARP-134-3202)
Intake Manifold Bolts - GM (17122601) - 2006 GMC Sierra
Exhaust Manifold Bolts - Dorman (674-014)
Exhaust Flange Stud/Nut - Dorman (03133)
Block Plug - GM (11609289) Coolant Drain Plug (Block Heater Delete)
Starter Bolts - GM (11610787)
Ace hardware and other hardware stores here in N. GA will rape you on price! I always visit a fastener store if I don't have what I need in my bins. Making another run tomorrow morning.
