Speed Inc 1579 HP Vid added
Old 03-07-2012, 09:27 PM
6 Second Club Moderator
LASTLS1's Avatar
Default Speed Inc 1579 HP Vid added
I took the car to Speed Inc today. We are heading to FL for the LSx race next week. I had to switch from a 3 bar map sensor to a 4 bar to get over 29 lbs of boost. These guys are getting crazy to keep up with!!!! lol So Jim had to rework the entire VE table.
We were having boost controller issues, we were going from commanded boost to base boost and back to commanded. Something electrical is going on, I will check it out tomorrow. We kept it on the safe side because of the boost issue @ 11.2-1. It made 1585 rwhp @ 27 or 28 lbs of boost, boost went down to 11 lbs after 6800 rpm. We wern't looking for numbers just getting the VE table close and we'll finish it in FL at the track. At least I can turn it up now past 29 lbs to run with these nuts!
FL should be fun!!!! Thanks again Jim, he was sick as a dog and stuck it out.
Old 03-07-2012, 09:38 PM
LS1Tech Sponsor
hellbents10's Avatar
Wow, nice numbers indeed and should fly down the track! What is the basic rundown of the engine?
Old 03-07-2012, 09:39 PM
Tiago's Avatar
wow, thats awesome. What turbos? you had TC76 at some point? can't remember...
Old 03-07-2012, 09:42 PM
GOrilla's Avatar
Big #'s man. Good luck @ the track, car should haul!
LASTLS1's Avatar
427, twin pt 76's, Speed Inc fabbed headers and turbo kit, soild roller, sheet metal, coil over, wet sump.
Old 03-07-2012, 11:02 PM
LS6427's Avatar
Heads?
Block?
Old 03-07-2012, 11:11 PM
M2W-GTO's Avatar
Awesome numbers!
Old 03-07-2012, 11:26 PM
RoidedSS's Avatar
so almost 1600 hp and your "ironing it out still". haha that is just awesome and makes me jealous. good luck down in florida, speed inc did my car and it ran awesome, I can't imagine how your car runs
Old 03-07-2012, 11:31 PM
studderin's Avatar
hell ya
Old 03-07-2012, 11:48 PM
qqwqeqwrqwqtq's Avatar
All that work to re-tune for the 4 bar map and we don't even see 30psi
Awesome #'s Andy, I'm glad we put 4 straps on the back
Old 03-08-2012, 12:13 AM
Rickys S/C Z28's Avatar
wow!!!!!
Old 03-08-2012, 04:48 AM
venom ws7's Avatar
WOW thats nasty !!
Please tell me you have some vids ?
Congrats Andy and great work like always Jim.
Old 03-08-2012, 05:51 AM
JAX04's Avatar
Simply..... ****!!!!
In for pics and a dyno vid
Old 03-08-2012, 10:07 AM
LS1 SPEED INC.'s Avatar
Video here: https://www.facebook.com/SpeedIncUSA/
Old 03-08-2012, 10:26 AM
LASTLS1's Avatar
GM LSx block, ET LS7 heads
Old 03-08-2012, 10:36 AM
Fbodyjunkie06's Avatar
Did you ever get the converter re-done from the last race? I guess the map sensor and the converter is what was holding the big boost numbers back.
What does it get turned too normally rpm wise?
Are you using an AMS1000?
Old 03-08-2012, 10:46 AM
LASTLS1's Avatar
Yes it's a new converter. We just ran out of time, we could have turned it up but we got what we needed to done. Also the boost controller was acting up. The rest can be done at the track.
Old 03-08-2012, 10:47 AM
427's Avatar
Where did the power peak at? Sounds like the converter is loose, higher boost may not help. What input is your converter?
Kurt
Old 03-08-2012, 10:52 AM
87silverbullet's Avatar
For all of you that have old *** work computers like me.
http://www.youtube.com/watch?v=Rt74I...ature=youtu.be
Old 03-08-2012, 10:57 AM
LASTLS1's Avatar
Kurt
Converter doesn't seem loose, it's a new PTC. I'm not sure on the converter or rpm. I didn't change anything with the engine so Jim was just rebuilding the VE table for the 4 bar. We didn't print out any dyno sheets.
Quick Reply: Speed Inc 1579 HP Vid added
