Drag Racing Tech - What size tire th350 and possible nitrous
ccd_1606
03-08-2012, 07:40 AM
Just wanted to see what everyone thought about for tire size on my car it has a th350 and a 3.42 rear end gear, once its dialed in on motor i plan on spraying 100 to 150 shot. With that being said which size drag radial should i go with a 26" or a 28"? ill be running 15x10 wheels in the rear.
krissoto
03-08-2012, 06:42 PM
275/60 hoosier
AChotrod
03-08-2012, 08:56 PM
How much power NA?
ccd_1606
03-08-2012, 09:04 PM
well it hasnt been dyno'd since the trans swap, but the dyno sheet that came with the car when i bought it said 448 that was with a t56.
TurboStangJON
03-12-2012, 11:58 PM
275/60 I have trapped 130@6800 on motor with a TH350/4.10's/275.60 so you should have plenty of room for nitrous. I'm spraying my combo but only in the 1/8th.
AChotrod
03-13-2012, 10:36 AM
You could prob run a 275-50 and be faster than a 275-60 if you can hook it. Im running a 26" hoosier DR and a 3.55 this year. About the same HP NA but Ill be hitting it with 150+
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
