Drag Racing Tech - Going for the Record
BMPJohn
03-08-2012, 08:46 AM
Hey guys, this is only my 2nd post here, so I hope I'm not doing anything out of line. I am going to spend some more time here getting to know the LS crowd. I wanted to let you know of a project we're doing since the people involved are posters on this site.
BMP has teamed with Baker Engineering to put together their new engine and go for the world record in 1/4 mile.
BMP's Impala is shooting to run 6.X making a target 3000 HP completely on our LS heads/Block platform.
We will be putting out a newsletter on the monthly basis following 3 builds, this is one of them. When I get the site set up, you can submit an email and get updates on how things are progressing.
We wish Baker a lot of luck, and hope to put down some new record times.
__________________
BMF_Racing
03-08-2012, 08:55 AM
Any idea on timeframe for the finished car?
sweetbmxrider
03-08-2012, 10:12 AM
3000hp, has a nice ring to it.
autogeek23
03-08-2012, 10:14 AM
post updates asap. sounds good
BlackScreaminMachine
03-08-2012, 10:43 AM
Love to see the results and will be impressed on the reliabily exceeding the 3-4 HP per cubic inch threshold that most have issues with.
BMPJohn
03-08-2012, 11:09 AM
I am going to let the guys at Baker address that. I know they are anxious to run it this season.
94LT1TA6spd
03-08-2012, 11:13 AM
:pics:
Sorry... I had too :D:D:D
Fbodyjunkie06
03-08-2012, 02:13 PM
The impala is already built.
It runs on E98, twin T6 88mm turbo's, non intercooled, 438 cubic inches (IIRC), and has run 6.98@20x so far correct?
Outlaw666
03-08-2012, 06:38 PM
well...pics would prove that this vehicle actually exist lol...I wanna see pics, sounds cool!
BMPJohn
03-08-2012, 09:01 PM
http://www.yellowbullet.com/forum/showthread.php?t=455720
hellbents10
03-08-2012, 09:28 PM
Here you go guys I am sure you might Have seen it before, we went 6.95 with the car bringing it out only 4 times. It was a whole new car, engine setup and Dave had just made his license passed prior to this.
It had a LSX block and 235cc runner heads on it running non-intercooled on ethanol. 4.5hp/per cube and no issues in 38 passes.
Now we will be running a REAL set of heads and MUCH better block thanks to BMP!!! We are also switching to methanol for fuel. We are looking to work our way down the 6s to possibly 5s if all goes well. 60psi should do the trick!
Turbos will remain the same till we see some backpressure issues, then FI will rework the turbine sides. We are running Garrett 47-88s.
The block has arrived and it is a very nice piece! John, and I will post pics as the build progresses now. Parts are being made as of 4 weeks ago.
http://pic80.picturetrail.com/VOL2018/11086975/22771147/394934771.jpg
Wnts2Go10O
03-09-2012, 01:38 AM
beautiful car. good luck on knocking down the record. Casper and the old W2W crew will be pleased.
i6overboard
03-09-2012, 10:38 AM
dayum car looks good. Finally someone pushing the lsx platform to the absolute limit, im really interested to see how it holds up to that kinda boost/power level.
94LT1TA6spd
03-09-2012, 12:09 PM
Wow, looks badass.
Would love to see a couple vids of the runs it has made!
87silverbullet
03-09-2012, 03:02 PM
Its crazy how casper did it with a 352 cu in engine and everybody is using 420+ cubes to get there. Then it was done damn near 7 years ago.
Best of luck guys! Show the world what these LS engines can do!
hellbents10
03-09-2012, 03:54 PM
We went 6's non-intercooled on a different fuel though, and here is the 6.95 pass. Also with no nitrous to get it off the line Casper had spray and 80mm turbos. SO the 420+ci is justified in my eyes to get 88s lit fast on the line.
http://www.youtube.com/watch?v=qnrtlaQolug
camaroandreas
03-10-2012, 07:40 AM
It sure will be a fun year. Now i have to boost the shit out of my new engine:)
camaroandreas
03-10-2012, 04:08 PM
Bmp already sponsors the worlds fastest lsx:)
My little 352 held the record until Andreas ran his Monte Carlo. I think the record lasted because we don't have any classes here in the states that put these engines in lightweight big tire cars. I believe you will see some of these radial guys get into the 6's this year with LS power, the big tire lightweight stuff will go in deep! The 352 had 205 AFR 4 bolt heads on a factory block out of a pickup truck!! It was the best parts available at the time, AFR had the only head! My how times have changed......
KurtIts crazy how casper did it with a 352 cu in engine and everybody is using 420+ cubes to get there. Then it was done damn near 7 years ago.
87silverbullet
03-10-2012, 09:28 PM
Kurt
Thats what I was getting at. Look at all the cylinder head options out there now compared to what was out there then.
Did you think it would evolve this fast Kurt?
Wnts2Go10O
03-10-2012, 11:16 PM
Kurt
and a blowoff valve on the coolant system :jest:
its awesome how the LS platform has progressed
Fbodyjunkie06
03-11-2012, 12:25 AM
That motor engineering wise was waaaaaay ahead of its time.
Deck surface and sealing wise, it was in the stone age. They had to mop up the water it pushed with a bucket after each run due to 4 bolt heads and no readily available aftermarket block to accept a 6 bolt head.
As TJ said they also used nitrous to spool the turbo's and to assist power to the 330' probably then shut it off and let the turbo's work in their pressure range.
I thought at the time the record would not last, I wanted first in the 6's. Ronnie Duke went 6.9X within 3 weeks of our run and Mark (can't remember last name) in Australia running with help from Con and Vic was breaking transmissions but ran a few 7.0X runs. Every time he tried to take off hard the trans broke.
When I ran Marks engine I only had the 4000G dyno and it gave up around 1600hp, so not sure what his would have made. It had a single cast wheel 106 then and I think the boost psi was only 25 when the dyno steamed the brake. Mark was around 2500 pounds, Casper was around 2900 and Andreas is down lighter than both. The UTE is running again in Australia with a 427 6 bolt engine still using cathedral heads and the original induction except for head castings. He still runs a powerglide but latest reports are good as it was holding.
The Pro Mod Dave has is pretty cool, although I have never seen it in person. I would watch for the three to trade the record around a bit this year if all goes well.
Good luck to all!!
Kurt.Thats what I was getting at. Look at all the cylinder head options out there now compared to what was out there then.
I still remember changing the springs in the blow off valve trying to get it to hold 30psi!!
I built the engine for a class here on tech, when that died I borrowed Casper for some fun!
Kurtand a blowoff valve on the coolant system :jest:
camaroandreas
03-11-2012, 10:14 AM
2540 lbs is the weight of mine. But i only have a total of 10 runs on my car before i hit 6.73 . On it´s third run i ran 6.88 . I´m still learning.
I understand that! We ran Casper around eight times, it went to the end of the track under power 2 times. The first trans would not go in high gear and ruined the first 5-6 runs. The first run under power it went 7.02@202 on 25psi so I turned it up and shook the tires so hard the rear wheel bearings broke. I took it home and fixed the wheel bearings and replaced the front brakes as only one chute opened on the 202 pass and we cracked both front rotors. The next pass it went 6.86@205, after that we ran Mike's Monte Carlo as we brought that also for testing.
Kurt2540 lbs is the weight of mine. But i only have a total of 10 runs on my car before i hit 6.73 . On it´s third run i ran 6.88 . I´m still learning.
camaroandreas
03-11-2012, 11:21 AM
I have modified the car a LOT this winter. Will post some pictures soon:)
This is the last season with lsx. A bae or aj 526 would fit nicely:)
BMPJohn
03-11-2012, 02:34 PM
Kurt
Thanks. Here's a few good examples.
Our heads are very different in the valve geometry. We changed the angle from stock so that when you shim the stands, the rocker doesn't move around on the valve stem, it simply goes straight up right where it was.
This allows running far more lift and a taller valve. Our valves are 5.300 and 5.330 and require a 8.600 push rod, but if you're going for all out performance, this geometry helps with valve control and provides for more lift, we're the only ones on the market doing this, everything else is just a stock kock off. This also allows for much bigger springs to be used. We believe we've solved some of the short comings with LSX stock design. It requires a little more knowledge when doing a build in terms of geometry, but it's effective.
We also put more water around the chambers, to cool the chambers more, allowing for more compression and timing.
Fbodyjunkie06
03-11-2012, 03:16 PM
I would love to hear more about how you all are doing this.
You will be the reason the LSX get's into the 5 second zone.
Can't wait to see what is next.
camaroandreas
03-11-2012, 03:46 PM
Which heads are you talking about?
That's cool John! My AFR heads had 1.550 springs, 5.5 long valves and the pushrods were 1/2 inch in diameter and over 9 inches long. I put thick spacers in the seat area to jack up the spring seat so I could get the larger springs in. We then built a jesel bar that moved the rockers back so far I had to weld up the outside of the cover cause clearance caused the rocker to sit outside the cover.
The newer All Pro 12-1 and 12-2 take care of all these problems but still require the longer pushrods of course.
KurtThanks. Here's a few good examples.
BMPJohn
03-12-2012, 04:44 AM
Kurt
You can run BBC springs on our heads because when you move it up, it goes straight up, no welding would have been necessary. Some clearance may be needed by the valve cover rail, based on the rockers, but very minor modification.
I haven't seen the all pros, but ours price out at $2800 for the top of the line CNC'd LS7 CNC'd head. That's a 296CC, completely assembled, some dealers will cut a deal. Probably looking at $2500 or so, but I can't speak for the dealers.
camaroandreas
03-12-2012, 04:55 AM
BMP LS7 heads? These are the ones i will run:)
hellbents10
03-12-2012, 07:29 AM
Kurt, your car was flat hauling a long time ago, nothing short of amazing!
We are going to fill the block and dry deck the heads so no worries of pressurizing the cooling system. Not to mention the 9/16" head studs and the 7/16" outer should help with power production.
Send me info on the 2800 dollar top of the line LS7 heads at kuperf427@yahoo.com, I am curious valve supplier and material used and flow numbers/valve sizes if you have them.
Thanks
KurtYou can run BBC springs on our heads because when you move it up, it goes straight up, no welding would have been necessary. Some clearance may be needed by the valve cover rail, based on the rockers, but very minor modification.
hellbents10
03-12-2012, 08:48 AM
That is very impressive, I think you did a great job of getting the car down the track. I look forward to seeing the LS record get swapped around this year!
3stgstocker
03-12-2012, 08:50 AM
nice car i remember helpn tootee build that thing along time ago for harmons restoration. tootee called me a while back and said yall had a ls in it and was wantn me to come and check it out since thats all we mess with now. i promise u wont find a better car builder and he is a real smart guy! good luck and keep us updated!!!!!!!!!
hellbents10
03-12-2012, 08:53 AM
Wow some one that knows Tootee on here! I agree with you the car was built in 94' and it was way ahead of its time!!!
I want to see that new Camaro go down the track!
camaroandreas
03-12-2012, 10:00 AM
Hehe i have also done that.
BMPJohn
03-12-2012, 01:56 PM
Thanks
Kurt
Hey Kurt,
here's a link to the heads:
http://www.theengineshop.com/products/warhawk-12-ls7-aluminum-heads.html
The Valves are MANLEY stainless steel.
As to flow numbers, we're not huge believers in them, the joke around the office is "what do you want them to be"... and I know you guys are smarter than to use flow numbers to determine anything...We advertise our flow numbers here:
http://www.theengineshop.com/product_images/product_pdf-pdf_file-209.pdf
Note we post both 600 and 1200 benches, we flow without a pipe, etc...etc...etc...
Customers have told us that they consistently flow more than advertised, and maybe not as much as some PEAK advertised numbers, but more across the board.
Fbodyjunkie06
03-13-2012, 01:51 AM
I cannot believe Kurt's and Mike's Kasper car had AFR 205's on it that BLOWS my freaking mind man.
I knew they were 4 bolt, and I knew they were old school(ls wise), but I didn't know that they were AFR's.
Neat looking head John. Curious:
What does intake valve weigh?
What springs come on it?
What adjustable valvetrain fits?
What size bolts hold the valvetrain on the head?
KurtHey Kurt,
BMPJohn
03-13-2012, 09:43 PM
Kurt
Hey Kurt,
The intake weight, I have no idea. They are Manley Severe Duty 5.300 intake valves.
http://www.manleyperformance.com/pdfs/06/Valves-3-50.pdf
Springs are:
http://www.theengineshop.com/products/head-components/springs-shims/ls-chevy-valve-springs.html
Pretty much the same source as everyone else in the industry that is selling springs.
Stock or Jesel rockers work or equivalent.
As to the size bolts, good question, no one ever asked. I'll check it out and get back to you.
Here's the tech sheet link:
http://www.theengineshop.com/product_images/product_pdf-pdf_file-39.pdf
JustJewIt
03-14-2012, 06:05 PM
:werd: Will definitely be keeping up with this build. Can't wait to see what the car runs when it is finished.
Stelth
04-09-2012, 01:49 AM
Hey Guys,
It's great to see people pushing to new limits on this platform !
We took the Australian car out last week and ran a PB of 6.89
It's doing consistant 6's with the LSX filled block but now weighs 3000lbs with the driver :(
I suppose It's not too bad considering it started life as a real car .
Finally adding some boost,
greetings from Down Under :cheers:
http://youtu.be/mrfTDGaQCzU?hd=1
http://youtu.be/Xtt1j9gn7LI?hd=1
Fbodyjunkie06
04-09-2012, 09:04 AM
Hey Guys,
NICE!
Keep pushing the envelope my friend and throw the boost to that bad bad girl!!!:D 6.89 is awesome!
BTW the first 330' of that run to the 1-2 shift look effortless. You guys for sure have that car on rails!
COOKIE MONSTER
04-09-2012, 10:57 AM
Good luck man!
