Fuel supply issue 67 camaro ls1 motor
hello,
Im having issues getting fuel to the fuel rail...
I have factory tank to airtex e2000 pump to corvette filer to fuel rail....
if i remove the filter i get gas coming out of pump and i hear the pump working so i know thats fine. Its a wix filter so i also know that it should be good. (everything is brand new)
HELP!
HELP!
ok so the outlet was easy cause it says outlet.... But seaching this site i see people connect the return and inlet at two different locations... My return is the outside line and the inlet is the one inline with the outlet.
Sound correct?
Sound correct?
