Huron Speed Complete Single Turbo Kit SPECIAL! $2299
Here is an intro into the new Huron Speed Single Turbo, truck manifold kit for 98-02 LS1 cars. This special is for the normal kit, PLUS turbo, waste gate, and BOV!
Many of you may recognize the user name as I have been a member on here for many years as an enthusiast. Same guy, just branching off doing what I enjoy! If you have any questions, that is what this thread is for, thanks!
I am a new vendor to LS1tech, but have been a supporting Vendor on CorvetteForum for nearing 2 full years now so have full confidence!
Thanks,
Jon
Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit
This special is for our standard Truck Manifold kit with a Turbo, Waste gate, and BOV for an unbeatable price!!!!
Special pricing on this kit is $2299.99 for forum members only!
Available via PM purchase only!
*This special is only open for the first 3 people! So act fast!!!!!
This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, etc as you can see from the picture! Kit includes all components to run either the 38mm or 44mm Wastegate, as well as to run a MAF or not!
All piping is made from 321 Stainless, yes 321!
Components:
-2.5" crossover with T4 flange and 38mm Wastegate Flange, dump to atmosphere
-38mm-44mm Wastegate Adapter Flange
-3" Downpipe with 3" V-Band flange (3" V-band on exhaust end also for easy to add on more exhaust)
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-All gaskets
-F-body front mount intercoolers brackets w/ bolts
-F-body alternator relocation brackets
PLUS Turbo, WG, and BOV
-ON3 76mm, .96 ar Turbo
-XSPower 38mm wastegate
-XSPower 50mm BOV
All piping made from 321 stainless steel, fully polished.
INCLUDES ON3 76mm Turbo, 38mm Wastegate, 50mm BOV
REQUIRES Oil Lines, and Truck Manifolds to complete
Being a truck manifold kit, you will lose your A/C
Will require removal or lowering of front sway bar
Kit retains factory radiator in factory position, just need to add pusher fans
Kits include what you see in this picture below, plus the turbo, gate, and BOV!
Note: Kit's come with BLACK silicone couplers, not the blue you see on the installed vehicle.
Thanks,
Jon
Components:
-MAF Delete pipe
-All gaskets
-XSPower 50mm BOV
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Thanks! Currently we are not doing installs and tunes, but will be in the future!
__________________
__________________
In all honesty I am not 100% sure. I think they are Chinese, but in any event I haven't heard a single bad report about them! I can also do kits with a turbonetics TC76 or 78 or even a Precision unit as well if interested, but cost will be higher of course
__________________
Nope! I think it's just the angle of the picture!
__________________
I am not completely sure what you mean by room for the down pipe. The down pipe is included, is 3" and fits just fine and clears all with the factory K-member. If you are running an aftermarket K-member you will have more space and could certainly run a larger down pipe, but everything is made to fit around the stock K-member
Stock fans need to be replaced for some pusher fans as the factory fans take up some prime real estate where the turbo is!
__________________
Get yours while you can, spots are running low!!!!
__________________
All kits ordered so far have now SHIPPED!
Therefore, the pre-sale is officially over, but I will let it run through Saturday for the special pricing! All orders from here on out will ship ASAP!
Jon
Jon
__________________
I'm new the forced induction scene and i am making plans on going turbo. these type of kits is what i was looking for. my question is i would like to keep my a/c since I'm going to live in AZ. So what I've read i can use a 6.0L header on one side to keep the a/c. may i still use it on this kit so i keep my a/c? I'm sure that'll just thow off all the piping on that side huh?
__________________
No plans for one at the moment. We are doing a kit for the TBSS next
__________________
