Nitrous Outlet Single Stage LSX Nitrous plate 78mm
Category: Engine - Power Adders
Price: $200
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): SC
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
The Nitrous Outlet Single Stage LSX Nitrous plates are the only plates available that are capable of safely delivering a precise atomized mixture of nitrous and fuel into the intake plenum.
These nitrous plates consist of the same technology that was originally designed for racers competing in a class that stated you could only use a single nozzle discharge or plate with a single nitrous jet no larger than .093 thousands. These racers were having issues zapping spark plugs and hurting pistons due to the nitrous discharge not atomizing correctly into the air intake path and equally feeding each cylinder.
After over a year of R&D, three different designs, and a lot of real world racing experience Nitrous Outlet introduced the Nitrous Plate design that would revolutionize the racing industry.
Nitrous Outlet is the only company that has racers using a plate system safely injecting large horse power levels through the front of the intake plenum. Our plate design has shown proven results time after time.
Our billet nitrous injection plate is only ¾ thick with a factory O-ring gasket machined in. Our unique discharge design can safely introduce a hard hitting pattern into the intake plenum while still maintaining a clean reading on all the spark plugs proving our product delivers the results they are designed to.
A product designed for hard core racers that deliver proven results both on and off the track.
Revolutionary nitrous discharge plate, machined from billet aluminum with six specially designed nitrous and fuel discharge ports capable of flowing over 400 horse power, factory O-ring gasket, black anodized and laser etched with Nitrous Outlet.
This custom billet plate use's multiple nitrous and fuel discharge ports that spray across the intake throat, completely saturating the intake air flow with the best atomized mixture possible.
For C5 Corvette applications part # 42000 is needed .
Made in the USA!
