Drag Racing Tech - Rear arm and chassis bracing
View Full Version : Rear arm and chassis bracing
PSI GUY
03-08-2012, 06:26 PM
I am in the process of building up the rear of my camaro now. My rearend came in, shocks, lower control arms, wheels and slicks....lol, and I removed the factory fuel tank as I'm going to run a fuel cell in the lower trunk area. Now, the thing is this, as I am not running the fuel tank and I have much more room, the standard rear bar and panhard bar I had planned on making adjustable ones from tubing and heim joints and changing the design and location of the upper bar. Not so much the panhard bar, but the upper one could definitely use some better bracing and strength.
Has anyone built anything different, I have a ton of ideas, just wondering what other people had built to see for reference. I am running a 4" exhaust over it, so more clearance the better.
spaulding
03-08-2012, 06:36 PM
Just take the upper brace off its not really needed espeacially if your building a strip car
PSI GUY
03-08-2012, 06:38 PM
I just figured it would be better to tie the frame rails together and it helps stiffen that brace for the panhard bar
5.3LJimmy
03-09-2012, 09:29 AM
I also removed that brace a long time ago.
i6overboard
03-09-2012, 10:31 AM
i think your idea sounds good, it definitely doesnt hurt to tie the rails together although it may no be needed.
