91 240sx..5.3l/4l80e swap
Old 03-08-2012, 10:02 PM
lq4powereds13's Avatar
Default 91 240sx..5.3l/4l80e swap
Figured id start one of these since i am getting closer to getting it on the road. It's a 91 240sx that i have put a lot of work into, always planned on doing the swap but just took some time.
Picked up the car in Jan of 09 for 300 bucks from a buddy of mine that ran a tow yard. Car definitely needed some work but the frame wasn't bent and i wanted something new so i figured i would save this from going to the jyard.
Here is how she looked the day i picked it up..
Got the car home and started ripping off the crap that was going to be replaced..
Fixed some minor rust and hacked off the old core support...
Welded on the new core support and installed fender braces..
Picked up two good shape fenders, hood, and a bumper. Mounted the headlights..
Started on the body work and wanted to get the car one color..
Picked up some Origin Lab type 2 50mm rear overfenders and a set of fr500 replica wheels. 17x9 in the front 17x10.5 in the rear..
Installed 5 lug, wheels(245/40's front, 315/35's rear), and primed rear fenders to match. I drove the car around a year like this.
Got tired of the primer look so i had it painted lexus desert sage metallic..
Old 03-08-2012, 10:15 PM
So then i finally started buying more stuff for the ls swap.. Picked up a L59 out of a 07 silverado with 20k on it winter before last..
Then picked up this 4l80e for a very good price, just had a buddy do a rebuild with a trans go hd-2 kit on it. Pic was when i first picked it up, just needed a good cleaning.
Ordered the moroso gto oil pan, took about 4-5 weeks to get it.
Motor decided to let go so it was time to pull it..
Car sat like the above for about 6 months while i picked up more parts. Picked up a yank sfi flywheel, ls6 intake/injectors/rail, slp underdrive pulley, FTI 3600 stall, had custom motor mounts made, etc..
Here is how the motor is setting currently with everything installed.
Old 03-08-2012, 10:17 PM
Decided to put it in last weekend so here is a few pics of it going in.. Had it in and out a good 3-4 times that day.
Ran out of daylight though so it will have to be pulled one more time to do a little more firewall massaging.
Old 03-09-2012, 01:31 PM
Nissan LS240's Avatar
nice swap, I know LS 240 is a blast to drive, I'm sure this one will too
Old 03-09-2012, 01:39 PM
Hmm they work for me.. But thanks!
Old 03-09-2012, 01:41 PM
had to open another internet window, pics load fine don't know what happened
Old 03-10-2012, 09:50 PM
Got the motor in its final spot, put the accessories on, and did a few other odds and ends.
Old 03-10-2012, 10:03 PM
montecarloss's Avatar
nice car and good work
Old 03-10-2012, 10:20 PM
MunsonAuto's Avatar
Motor positioning looks good for having a 4l80e behind it!
Old 03-10-2012, 10:49 PM
Thanks!
Thanks. Yeah we had to put it in, remove, then beat the firewall/trans tunnel a good 4-5 times. Haha. But it fits pretty good now.
Old 03-22-2012, 03:22 PM
02camaroburn's Avatar
Looking to do something similar to this but with a bigger engine. What are you doing for headers?
Old 03-22-2012, 04:14 PM
Be prepared to beat the living **** out of the trans tunnel and cut out the stock trans mounting points if your planing on the 4l80e as well. Literally had to put it in, see if it fit, then take it out and beat again like 5-6 times. Going with c6 ls2 manifolds for the moment (plan on either doing a turbo setup or longtubes eventually) then 3" on back.
Old 03-22-2012, 06:35 PM
71403's Avatar
What did that air intake hose come off?
Old 03-22-2012, 07:16 PM
04 gto
Old 03-24-2012, 10:06 AM
SE-R Spec's Avatar
is that the ls1 corvette accessory bracket? and is that the truck's alternator on it?
in short, what did you use for your front accessories? lol
Old 03-24-2012, 08:41 PM
It's all c5 accessories besides the waterpump which is a ls3 vette waterpump. lol.
Old 04-27-2013, 01:29 AM
Been a while since i have updated this..
Had custom exhaust done, 3in y to 3in back to a borla xr-1 and corsa tip.
Got the car wired up and did the first start about a week ago
Installed the c5 auto shifter today, fits surprisingly well.
Have to install ds and figure out the rad hoses still but that's about all i have left.
Old 04-27-2013, 07:11 PM
superbean's Avatar
Good looking car.. i've had a new s13's.. makes me want another one.
Old 12-29-2013, 05:55 PM
Turbo210's Avatar
Would you by any chance have a picture of how you transmission mount came out I know this is a old tread but I'll just like to get a idel.
Old 05-19-2016, 08:55 AM
Haven't updated this in quite a while. Finally getting around to installing the turbo/cam/q45 diff, etc..
Shout out to JMB performance for the stainless work on my hot side/cold side and exhaust setup. BOV will be getting powdercoated black as the red just stands out too much.
Quick Reply: 91 240sx..5.3l/4l80e swap
