Cooling setups on Boosted LS1 ? driven on the street
Old 03-09-2012, 10:42 AM
TurboZ28408's Avatar
Default Cooling setups on Boosted LS1 ? driven on the street
whats your cooling setup on your boosted ls1s ? i have dual Spal fans, one pusher 10" and a puller 14" on a griffen 31" radiator and cruising on the fwy is fine but once i get off and cruise city streets for a while it starts to heat up. After it warms up, two consecutive street dig runs it basically will not stay cool. I recall seeing a turbo camaro in TX2k11 and in the texas heat. how does it keep cool ? I'm about to chop the front end off and put some OEM taurus fans or something.
Old 03-09-2012, 10:52 AM
AutomagicLS1's Avatar
31x19 griffin radiator here with dual 2500 cfm flexalite pullers doesnt over heat in the summer. From what I gather pushers aren't worth a **** in the heat
Old 03-09-2012, 10:56 AM
code4's Avatar
fbod I assume? I have found that getting the right fans with shroud makes the difference if it will cool while driving. How are you fitting a 31" radiator? I have the 15X27.5 griffin. I had problems until I wrapped my pipes, got a turbo blanket and built a shroud with two 10" zirgo pullers. I had to make it fit but you may not be able to do two pullers.
Old 03-09-2012, 11:03 AM
running a GT4580R .. HUGE housings. but i may just need to relocate my battery and redo some piping to get some decent fans in there.
Old 03-09-2012, 11:17 AM
SPRAYED 01's Avatar
I'm running the same griffen as most on here that stand up the radiator. After trying many different fans I took some measurements and went to the junk yard.
I ended up with dual 10 inch fans in a nice shroud from an 02 saab 93 turbo. On the saab they were pulling through a rediator, condenser, and a large intercooler. I wired them up with the stock wiring and they work great. I had to do very little work for them to fit on the griffen rad. I haven't used my ac yet but with out it on still pulling through my condensor they work awesome.
Old 03-09-2012, 11:21 AM
pics of your install ?
Old 03-09-2012, 11:23 AM
SPRAYED 01's Avatar
I'm on my phone now but I can load some up after work
Old 03-09-2012, 11:26 AM
LS1NOVA's Avatar
Shroud is key.
Old 03-09-2012, 11:40 AM
E.rodz's Avatar
Are you running a shroud now.if not that will cure the problem.for sure.this forces all the site to get pulled with the fan.I would get rid of the pusher and run a single 16 with a shroud.
Old 03-09-2012, 11:43 AM
ws602's Avatar
Ron davis set me up with this set-up
Old 03-09-2012, 12:10 PM
pwrtrip75's Avatar
Stock fan works great. Just stood the radiator up and plenty of room.
Old 03-09-2012, 03:15 PM
TermnEatr's Avatar
Stock radiator, shroud from bob at brute, and spal extreme fan .....
Old 03-09-2012, 03:29 PM
dville_gt's Avatar
I am in a fox body w/a super restrictive lx front clip, running a/c and a 4" intercooler, I use a 3" double pass radiator and a 3.8l taurus fan, keeps it cool.
Old 03-09-2012, 03:30 PM
Hank Peabody's Avatar
If you run too little timing at idle and cruise it will run hotter than it needs to, make sure your timing is high enough at idle/cruise.
Old 03-09-2012, 04:20 PM
overhere's Avatar
i thought if timing was to high it would run hot? just asking to make sure the right info gets out there
Old 03-09-2012, 04:48 PM
MIGHTYMOUSE's Avatar
lt1 radiator and fans, factory air dam
Quick Reply: Cooling setups on Boosted LS1 ? driven on the street
