Carbureted LSX forum - another ls newb with questions
View Full Version : another ls newb with questions
72ls1
03-09-2012, 01:03 PM
What do you guys do about the coolant crossover? I don't have a spot in the radiator for it like I have seen done. What else can you do with it?
How do you run mechanical guages? Or is it just easier to run electric ones?
Are there any good kits for front drive stuff? All I need is the alt. I don't run power steering or ac
johnyrrr
03-09-2012, 01:28 PM
Tap a spot at the waterpump neck like other have done and run the steam port to that.
ZONES89RS
03-09-2012, 01:52 PM
I run mine into the heater hose, but the current swap will go to the WP.
There are tons of options for the accessories, depends on your clearance.
As for water temp, I found drilling a stock sensor out and tapping it for a -8 metric for a electric sensor works great, I jb weld it into the stock drilled sensor and then screw that back to the head.
