Returnless FI System
Old 03-09-2012, 08:20 PM
skydude's Avatar
Default Returnless FI System
Doing all the research I can on an LS installation for my 72' chevelle. One question I have is if the newer 5.3's and 6.0's are using a returnless FI systems does that mean the pressure regulator can be mounted at the tank and that a return line is not required?
Any help will be appreciated.
Old 03-09-2012, 08:30 PM
Rocketrod's Avatar
The pressure regulator is mount in the tank. For an LSx conversion I went with a Vaporworx tank from Ricks. It uses a 5th gen Camaro fuel module with an internal regulator and only requires a supply line.
Old 03-09-2012, 08:32 PM
moreengineering's Avatar
PM sent.
Jerry
Quick Reply: Returnless FI System
