Small Block & Big Block Chevy Specific - 1999 firebird
BIRDMAN216
03-10-2012, 07:44 AM
I bought a 99 firebird rolling chassis backin october and im just now getting around to this swap.The previous owner had it as his drag car set up for a 350/350 combo.It still has the v6 k member but he had some custom motor mounts fabbed up to accept the 350 engine and also a trans bracket for th350.There is no wiring harness either since he was running a carb.Recently i purshased a 87 & up gen 1 sbc.The cowl was already notched for the other motor. Since this guy was running a older model 350, will i have issues with the newer style block?I know the distributor sits way back against the firewall but i was wondering if the newer block has a taller distributor?
ram88gta
03-10-2012, 10:37 AM
no you wont what changes is the heads, and cam so you should be good to go. good luck
BIRDMAN216
03-10-2012, 01:01 PM
http://i1075.photobucket.com/albums/w430/PREDATORorPREY/bird.jpg
http://i1075.photobucket.com/albums/w430/PREDATORorPREY/bird1-1.jpg
http://i1075.photobucket.com/albums/w430/PREDATORorPREY/bird2.jpg
http://i1075.photobucket.com/albums/w430/PREDATORorPREY/bird3.jpg
http://i1075.photobucket.com/albums/w430/PREDATORorPREY/sbc.jpg
http://i1075.photobucket.com/albums/w430/PREDATORorPREY/ta.jpg
BIRDMAN216
03-10-2012, 01:06 PM
Does anyone know what motor mounts i need? I have the uppers that are bolted to the block, I need the ones that will attach the block to the brackets I have.
k_cash1432
03-10-2012, 08:26 PM
Looking at your brackets those are solid mount brackets they bolt directly to the block no mm inbetween
BIRDMAN216
03-10-2012, 09:56 PM
Thanks bro I appreciate your help. I talked to the guy that I bought the car from and that is what he told me also.
BIRDMAN216
03-12-2012, 04:49 PM
I want to paint my engine and motor mounts but they have rust on them. Will those rust converters work on the engine?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
