Superman09
03-10-2012, 08:31 AM
Here is your LAST CHANCE to get in on the pre-sale SAVINGS into the new Huron Speed Single Turbo, truck manifold kit for 98-02 LS1 cars. This special is for the standard kit, no turbo, waste gate, or BOV. For $1899.99. This sale ENDS in just one week on Saturday, 3/17/12 so don't miss out! After this standard pricing goes into effect at $2300
Many of you may recognize the user name as I have been a member on here for many years as an enthusiast. Same guy, just branching off doing what I enjoy! If you have any questions, that is what this thread is for, thanks!
I am a new vendor to LS1tech, but have been a supporting Vendor on CorvetteForum for nearing 2 full years now so have full confidence!
Thanks,
Jon
Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit
This special is for our standard Truck Manifold kit at the very last opportunity to get in on pre-sale special pricing!! Sale runs for ONE WEEK and ends Saturday, 3/17/12! :judge:
Special pricing on this kit is $1899.99 for forum members only!
Order direct from the website at: http://shop.huronspeedproducts.com/F-body-LS1-Single-Turbo-Truck-Manifold-Kit-FBodyTurbo.htm
*This special is only open until Saturday, March 17, 2012! So act fast!!!!!
Click HERE (http://shop.huronspeedproducts.com/F-body-LS1-Single-Turbo-Truck-Manifold-Kit-FBodyTurbo.htm) to Order!
This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, etc as you can see from the picture! Kit includes all components to run either the 38mm or 44mm Wastegate, as well as to run a MAF or not!
All piping is made from 321 Stainless, yes 321! :cool:
Components:
-2.5" crossover with T4 flange and 38mm Wastegate Flange, dump to atmosphere
-38mm-44mm Wastegate Adapter Flange
-3" Downpipe with 3" V-Band flange (3" V-band on exhaust end also for easy to add on more exhaust)
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-All gaskets
-F-body front mount intercoolers brackets w/ bolts
-F-body alternator relocation brackets
All piping made from 321 stainless steel, fully polished.
REQUIRES Turbo, Waste gate, Blow off Valve, Oil Lines, and Truck Manifolds to complete
Being a truck manifold kit, you will lose your A/C
Will require removal or lowering of front sway bar
Kit retains factory radiator in factory position, just need to add pusher fans
Kits include what you see in this picture below
http://i6.photobucket.com/albums/y231/WS6SnakeEtr/DSC000303.jpg
Note: Kit's come with BLACK silicone couplers, not the blue you see on the installed vehicle.
http://i6.photobucket.com/albums/y231/WS6SnakeEtr/DSC02302.jpg
http://i6.photobucket.com/albums/y231/WS6SnakeEtr/DSC02303.jpg
http://i6.photobucket.com/albums/y231/WS6SnakeEtr/DSC02285.jpg
http://i6.photobucket.com/albums/y231/WS6SnakeEtr/DSC02276.jpg
http://i6.photobucket.com/albums/y231/WS6SnakeEtr/DSC01843.jpg
Thanks,
Jon
Components:
-MAF Delete pipe
-All gaskets
