Generation IV Internal Engine - ENGINE GURU'S--Engine Leakdown Expectations.
ls427ray
03-10-2012, 03:38 PM
on a new, just broken-in engine with boost, what are normal acceptable leakdown numbers?
machinistone
03-10-2012, 09:35 PM
On a fresh motor with the rings seated properly 3-4%, couple more if the ring gaps are setup large for boost, with gapless rings you can see less than that.
racecar
03-12-2012, 02:01 PM
It's important that they are all consistant. If most are 3-4 and one is 8%, you have bad rings on one.
