trex cam and 5.3 stage 2.5 heads
i know this is a very large cam and I cant seem to find any info on the PTV clearnence, I want to run the 5.3 stage 2.5 heads with my Trex cam. Will this combo work?
find yourself a cheap pair of 243's and their best port job is only 995 http://www.advancedinduction.com/LSX...cGMLS2Head.php
LS1Tech Premium Sponsor
In my opinion, that cam is too big for a stock long-block AND for an engine with the Stage 2.5 5.3's. The few we've had come through here that we got the chance to check PtoV clearance were VERY tight. If it were mine, I'd only run an aftermarket casting that had better than stock valve-drop.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
well my current setup is a forged LME 370 with trex cam all stock top end. what do you suggest for heads? i only was thinking of the 5.3 stage 2.5 heads since they are a good price and flow well. I really didnt want to spend a lot of money on heads but my choices may be limited.
__________________
