02sslayer
03-10-2012, 07:19 PM
i am wondering about the 5.3L truck engine
#1 is the 5.3 the LQ4?
#2 can i get 408ci out of the LQ4?
reason im asking is, i have a 2000 gmc sierra with a 5.3Litre engine and i wana possibly take this motor out, make it a 408 and put it in my camaro. let me know whats up guys, thankyou in advance
02sslayer
03-10-2012, 08:01 PM
anyone? honestly, i just cant remember if its only the lq9 or if the lq4 is also good for 408
1badeagle
03-10-2012, 08:57 PM
Lq4 and lq9 are 6.0 engines. I dont think a 5.3 can go to a 408. Build a 383.
02sslayer
03-10-2012, 11:21 PM
really? i always thought the lq4 was the 5.3. oh well, thanks for the info
nascarnate326
03-11-2012, 07:35 AM
just make a bad ass 327 that rev's to the moon.
02sslayer
03-12-2012, 01:09 AM
thats a cool idea too but i want cubes
autodoctor911
03-12-2012, 02:54 PM
How do you propose to make a 327 that revs to the moon?
the 5.3 is the same stroke as a ls1/ls6 with a smaller bore, so RPM potenlial is less.
I would, however suggest putting a 4.8L(05+) crank in an LS2 or LQ9 block for a true 327(5.4L), well almost 328 actually, with a 4" bore and a 3.26" stroke. almost exactly like the original 327(4"x3.25").
or, you could just bore the 5.3 out to 3.9, and put a 4" stroker kit for a ls1 in it, and have a nice torquey tire scorcher.
I don't know how much extra a 6.0 block would cost, but If I was going to get a stroker kit, and I was not limited by any racing rules that limit displacement, I'd go ahead and get the bigger bore block. Or even go for an aluminum LS3 if it's going into a car that didn't have an LS originally.
But budget wise, it would probably give you best bang for your buck to put a ls1 stroker kit(3.898x4") since these are the most available kits on the market, and probably cheaper than finding a bigger bore engine. I don't think the 5.3 block will take much more than 3.898 bore. Maybe 3.903".
SweetS10V8
03-12-2012, 04:34 PM
Just a quick FYI:
Vortec = Engines
Vortech = Superchargers
chrisfrost
03-14-2012, 09:05 PM
To the OP ,,,,,,,I think You're thinkin of the LR4 which is an aluminum 5.3L and to put a 4.8L crank in an6.0 block would'nt work without getting custom pistons that had the proper compression height ,,,,,,,,,,it would be a really torquey engine tho . Go to Hot Rod mag and search "The 350 Chevy Should have made" ,,,,,,2 guys into engineering and physics ,,,,,,,took a 400 sm block bored it .030" over (4.155") and stuck a 307/327 crank (3.25") in it with Ford 6cyl 300ci rods narrowed and 58cc aluminum heads , stock cam , holley or a quadrajet , GM hei and LT's and engine made 435lb. ft. and 412hp on pump 87 oct at the crank ,,,,,,,not too bad
