Mustang guys with 400, 350, or glide transmitions...what shifter?
Old 03-10-2012, 07:28 PM
streetknight2's Avatar
Default Mustang guys with 400, 350, or glide transmitions...what shifter?
Just wondering what you were using for a shifter. I usually use Turbo Action Cheetah shifters, whY do you run and why
Old 03-11-2012, 09:23 AM
JAX04's Avatar
Hurst quarterstick, because its BOSS
Old 03-11-2012, 12:55 PM
1bad03snake's Avatar
Holcomb Motorsports shifter base with a hurst quarter stick.
Old 03-11-2012, 01:04 PM
LILHEMI's Avatar
im also on the fence about this. want something with an integrated button for the trans brake.
Old 03-11-2012, 01:06 PM
trav-tech's Avatar
i run b&m pro stick
Old 03-11-2012, 01:15 PM
dkbmxer002's Avatar
cheetah > *
Old 03-11-2012, 01:52 PM
SN-95's Avatar
I run a pro-stick, it's been working great
Old 03-11-2012, 03:52 PM
78supersport's Avatar
Cheetah mounted in the ashtray slot.
Old 11-06-2013, 07:36 PM
speedshifter's Avatar
Those of you using a Cheetah shifter:
What did you do to make your headers fit with the shifter bracket?
LS swap with dynatech headers and the collector needs to go up another 3/4" to line up with the bolt holes in the head. I've been researching and it seems like its a common problem with c4 trans' in the mustangs too. Unfortunately, nobody posts with their solution to the problem.
Ideas?
Old 11-06-2013, 07:43 PM
Gray86hatch's Avatar
I have never had a problem with the Hurst bracket on my c4 with any headers I have had. The Hurst bracket puts the cable up high.
I have had bbk with the ford and dynatech with the lsx.
Tim
dmracing's Avatar
Precision Performance Product. Best shifter around
Old 11-06-2013, 07:54 PM
already got the Cheetah obviously, so trying to make that work.
several posts online say people have problems with the cheetah shifter bracket and mustang headers, but no solutions. SCS practically beats you over the head in their instructions say don't use any lever/bracket besides one designed for the cheetah...
Old 11-06-2013, 10:25 PM
streetlegalls1's Avatar
B&M pro stick,you can change the gates.
Attached Thumbnails Mustang guys with 400, 350, or glide transmitions...what shifter?-img_0766.jpg
Old 11-07-2013, 10:59 AM
I moved the cable to the other side of bracket. So it is between trans and bracket
Old 11-07-2013, 11:07 AM
I put a call into Dynatech yesterday and Greg called me back today gathering all my info. His R&D dude won't be in until Monday so they are going to call me on Monday and see what they can do. Really a cool guy to deal with and very willing to make this right.
Old 11-07-2013, 03:04 PM
MustangLS's Avatar
I went with a B&M Pro Ratchet shifter in mine. The B&M shifter bracket mounts up higher towards the pan on my TH350.
Old 11-21-2013, 11:56 PM
You were 100% right. Just did this tonight and it worked perfect. No header modification needed.
Old 11-22-2013, 05:37 AM
Glad it worked for you
Old 11-22-2013, 10:47 AM
ion05's Avatar
anyone know if f body shifter will fit fox body swap? or will it hit using a 4l60e trans
Old 11-22-2013, 06:44 PM
Quick Reply: Mustang guys with 400, 350, or glide transmitions...what shifter?
