Dynamometer Results & Comparisons - TT 2005 C6 @17psi 1031RWHP ON PUMP GAS AND METH
XPerformance
03-12-2012, 06:40 AM
Just finished another TT corvette with APS kit and 427 LSX Made 1031rwhp@17psi
it's a 2005 corvette c6
-XP 427LSX with TFS 245 heads 9.45CR
-DP CUSTOM TURBO CAM
-MODIFIED APS TT KIT
-T6060 DRIVETRAIN
-RPS TRIPLE DISCS CLUTCH
-XP CUSTOM FUEL SYSTEM WITH 83LB INJECTORS @90% DUTY
-ALKY CONTROL METH KIT
-PDFAT COIL OVERS
-EBOOST 2 BOOST CONTROLLER
-CORSA CATBACK
-z06 widebody kit
-2.5 SD TUNE
built and tuned @ xtreme performance Kuwait
here's a vid of the car
http://www.youtube.com/watch?v=BkkzG4BtNw8
venom ws7
03-12-2012, 08:03 AM
Like always great work :D
XPerformance
03-12-2012, 08:21 AM
thanks :D
nodrok
03-12-2012, 10:46 AM
1000+hp is always exciting. good work.
fattydre
03-12-2012, 05:01 PM
Why was the wideband reading so rich?
Mike@Diablosport
03-12-2012, 05:29 PM
Wow, you guys dont mess around over there, sick.
About what RPM was peak power there? I know these things have like 2.56 gears or something and the km/h ain't helping me figure it out either :)
same o'j
03-12-2012, 11:40 PM
Awesome , Ur still the best tuner. thanx for tuning my car last time ;) and hopefully ur going to tune it again after the 100MM MAF :D
XPerformance
03-13-2012, 04:04 AM
It's 11-10.8 where it should be with meth then it goes to 10.1 up top but i tweaked it after the last run
XPerformance
03-13-2012, 04:08 AM
The turbos had some issue in the last run they should start spooling at 4800-5000 and it should make max power and max boost at 5700-5800 , but last run they spooled late and peaked at 6300 where it made max boost there, found the issue and fixed it but didt put it on dyno again
XPerformance
03-13-2012, 04:11 AM
Lol will think abt it
RealQuick
03-15-2012, 10:51 AM
Which turbos?
yonerhottlt1
03-16-2012, 09:07 PM
Holy horsepower!
XPerformance
03-17-2012, 06:22 AM
Which turbos?
Gt35r
FreakChevy
03-23-2012, 10:01 PM
You mean full boost at 5700-5800?
Cold Zero
03-26-2012, 02:06 PM
Gr8 result Faisal as always .. those projects you did give me nice feeling that I choosed that right hands to do the magic soon :D
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
