Pontiac GTO 2004-2006 - Cluster an some interior lights not working.
youngbuck
03-12-2012, 01:01 PM
Ok so parked the car friday night all was well, drive the car tonight an the cluster, ac controls, headlight switch and the blinkers are not lighting up, the blinkers wont light up unless the switch or the hazards are used. I checked the daytime running relay an swapped it with a working one with no change. Haven't had any problems until this an now the headlight sign on the dash won't turn off with the lights on, headlights, fogs, radio, window switches and the 3 green sections on the cluster are working fine.
Jontall
03-13-2012, 04:31 AM
Check your BCM wires: http://www.ls1gto.com/forums/showthread.php?t=377773
Next, there is a cluster of wires by the battery and sometimes the battery pinches them. Remove the battery and check that they are not chaffed/pinched (look very closely) and completely out of the way when the battery is in the tray.
youngbuck
03-13-2012, 06:34 AM
Is the glove box hard to pull?
Jontall
03-13-2012, 08:34 AM
It's easy. There is a little rubber stop (5) that needs to be removed. Go slow and don't force/break anything.
http://ls1tech.com/forums/attachment.php?attachmentid=344489&stc=1&d=1331645662
