can NX parts be used along with a TNT kit?
Im checking into all the parts I want for my nitrous kit. I want to order the TNT F1 kit and the MSD window switch, but can I use the NX fpss and the NX WOT switch with the TNT kit, or are they only for use with the NX kit? Thanks!
The Bull
Yup, they should work fine. They are not really related to the jetting components. Things you should avoid are really mixing jets and solenoids. Mixing bottles is ok. Some bottles are better then others (actually the valves). The TNT bottles warm up in the sun quite nicely compared to the white NX bottles! Sorry to digress, but that should help you out.
Originally Posted by SStolen
TNT kit comes with a WOT switch. I'm thinking maybe even a FPSS too, probably not though.
Originally Posted by Donate52
i did not know that, i didint see it in the online description of the kit so i assumed the kit came without them. ill look into that, thanks!
NX does sell a nice TPS based WOT switch, for the ultimate in clean installs.
you can mix and match almost every NX and TNT part, including the noids, as they are the same, or nearly identical.
Ryan.
