Dyno Guesses & Bench Racing Forum - Guess What Will it Make Tomorrow?!?!
jtaylor16
03-12-2012, 02:25 PM
my car gets dropped off at the tuner tonight, let me say first that i dont really care what it makes, my goal is to just get faster and faster in the 1/4 mile. but i figured Id let people play the guessing game.
00 Camaro A4
setup:
-stock 346 bottom end
-ported 241 heads with trick flow .660 lift dual springs and retainers
-bullet cams 234/236 .650/.650 lsa112
-ls1 mani with ported plenum
-ported throttle body
-slp ram air and lid with modification for more flow
-kooks 1 3/4 long tubes
-2.5" custom bent true duals
-deleted egr and air, descreened maf
-4l60e trans with midwest converters 3600 stall and b&m transcooler
-10 bolt with gm performane 3.42s
car will be on stock wheels and street tires for dyno purposes and will be tuned with HPtuners on a dynocom 5000 series dyno
Johnnystock
03-12-2012, 06:20 PM
391rwhp
Camaroking1996
03-12-2012, 06:24 PM
426rwhp
trey1010
03-12-2012, 09:10 PM
417rwhp
njmaster
03-12-2012, 09:17 PM
395 rwhp
thunderstruck507
03-13-2012, 10:35 AM
If you want the car to go faster get rid of that. I would have done it before the tune so the tune would be correct for a decent intake.
Ls6 intake minimum for a head/cam car, especially with your size cam.
I'm going to guess 390rwhp. 410rwhp with a decent intake manifold.
Midnight02
03-13-2012, 10:47 AM
I'm going 412 rwhp. As stated above, pull that LS1 intake off and the numbers should be considerably better!
jtaylor16
03-13-2012, 11:38 AM
all in time fellas, im considering just saving to do a carb mani with and elbow setup in the future
Johnnystock
03-13-2012, 12:34 PM
Auto and LS1 intake wont get you dyno queen numbers. Stock wheels and gears will help though. I'm still thinking youll be lucky to be above 390(depends on the dyno I guess).
jtaylor16
03-13-2012, 01:44 PM
Ill let you guys know as soon as I hear from the tuner. Im really hoping for something in the 415-420 range even though dyno numbers mean nothing to me. car was built to win races on the street and thus far as been pretty good at that so as long as performance there increases im happy. street king > dyno queen
nmass399
03-13-2012, 04:43 PM
420 on that kind of dyno i would have to guess.
litle88
03-13-2012, 06:26 PM
380-390 with that intake and small TB.
GL, did you get results yet?
LS1 proj
03-14-2012, 02:32 AM
408whp
Johnnystock
03-14-2012, 01:03 PM
:corn:....
Midnight02
03-14-2012, 02:35 PM
And the winner is?
heavy6.0
03-14-2012, 10:23 PM
370rwhp with stock LS1 intake and auto.
jtaylor16
03-15-2012, 07:58 PM
tuner had to push me back due to having issues with other other cars that were infront on me to get tuned should have numbers for u guys tomorrow
Forced_Induction
03-16-2012, 11:50 AM
390rwhp
Johnnystock
03-16-2012, 02:07 PM
I think you have the best bet :secret:
thunderstruck507
03-16-2012, 02:51 PM
If the converter is unlocked for the pull it will almost definitely be between 360-370rwhp.
I'm assuming the heads are professionally ported.
Orange Juice
03-16-2012, 08:44 PM
You are really holding it back with that intake.
jtaylor16
03-17-2012, 07:05 PM
Camaroking1996 is the winner car made 420, 424,and 42. one more pull to go
MikeWS6
03-17-2012, 07:26 PM
lol what dyno was that on?
jtaylor16
03-17-2012, 07:41 PM
Dynocom5000
jtaylor16
03-17-2012, 08:20 PM
final numbers 425/434
litle88
03-19-2012, 04:50 PM
Post those graphs and video if you got one.
Johnnystock
03-19-2012, 05:24 PM
434 rwtq? That seems off for sure.
PewterScreaminMach
03-20-2012, 10:11 AM
It's a Dynocom dyno. Not really comparable to a Dynojet's SAE-corrected numbers, which is sort of the standard if you're gonna bother comparing dyno graphs and numbers. Otherwise, it's pretty much just a tuning tool.
Of course, I'm sure the dyno operator mentioned that this dyno just happens to be a "heartbreaker", like every other dyno in the world...:jest:
As long as you're happy and the car's running strong, OP, that's what matters.
bad94sup
03-20-2012, 11:03 AM
Dynocom5000
Who has one of these in the Philly area? I was assuming you were using RPM in Delaware and they have a Dynojet.
If you're curious as to how the dynos compare, RPM is running a dyno day on Saturday April 21st. $50.00 gets you a couple pulls. :D
jtaylor16
03-20-2012, 11:08 AM
twisted tuning in fairless hills PA, injection connection which is also in the area also has a dynocom
jtaylor16
03-20-2012, 11:10 AM
waiting on the graphs to be emailed to me but i think the torque went down a lil as the hp went up. i think first pull was 420/434 but by the time we got to 425 it was around 415-410
