Paint & Body Work - How bad is it??
chevrunner21
03-12-2012, 06:58 PM
so long story short, trans got stuck in 4th gear when i was in delaware, i live in nj, i drove the car home, parked it infront of the house downhill so i could take it around the block to my buddy with a lift when we had time to tear into it and see what happened. Things took longer than expected so i dropped the insurance while the car was still parked out front of my place and dont you know in the middle of the night car gets hit and run!:bang: ive never ripped the front end off one of these, only ever done old 80s gm trucks, car is 2002 ws6.
sorry about crooked/shitty cell pics, car is now in a driveway and this damn work comp wont let me rotate the pics car was hit right where the driver fender meets front bumper and seems to me pushed in pretty good. fender is rubbing the door.
warriorcustoms
03-16-2012, 08:51 AM
Its easy Just time consuming Lots of stuff to take off before you can get to the places you need to
chevrunner21
03-16-2012, 10:26 AM
really?? whats it look like needs to be repaired? Me and a buddy are gonna put it on his lift and drop the trans so i figured id mess with the fender and all while he plays in the trans just waiting until neither of us are working
v7guy
03-17-2012, 04:47 AM
All the panels are plastic, so outside of fixing the scuff you should be good as far as $$$ goes
There's a small metal bracket behind the bumper around the bumper/fender seam. My guess is it's bent and needs beat with a hammer a few times to be straightened out. I don't remember if you can get to it through the splash shields underneath or if you need to pull the front bumper.
Like warriorcustoms said, time consuming... but not all that difficult.
chevrunner21
03-17-2012, 07:14 AM
you guys made my st.paddys day thanks for the info. I've been pretty pissed off about it since it happend, i think it was the neighbor across the street from me that did it but i cant prove anything, and I'm pretty sure the bastard called the cops about the car being in the street because local pd came up the following day saying there was a complaint. Again thanks a bunch guys
chevrunner21
03-17-2012, 07:26 AM
also just that little bracket would allow the fender back far enough for the door to rub?
v7guy
03-17-2012, 12:22 PM
No, if the fender moved back you would probably need to take a look at all the mounting points. There's one under the car. There's one on the inside of the fender by the door about halfway up with rivets then the group along the top. I would probably loosen them all then adjust the fender accordingly after the previously mentioned metal bracket up front was removed, straightened and put back on.
It'll be a pain in the ass, but it'll be free. The big thing is take your time and be patient. If need be, walk away and come back.
chevrunner21
03-17-2012, 03:26 PM
Ill prolly be doing a lot of walking away and coming back lol I don't break my own things when i get frustrated while working on them, i cant afford that lol. thanks again
Ismokem
03-28-2012, 09:31 PM
Definitely better than beating it with a wrench
chevrunner21
03-29-2012, 06:25 AM
lmfao
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
