Carbureted LSX forum - cam votes needed
View Full Version : cam votes needed
rocketman19851985
03-12-2012, 10:33 PM
Wanted to know what you guys think? I am running a jr intake eb750 carb and a 200 wet shot:D the rest of the motor is all stock. I was thinking either the ms3 or the torquer v2. I am open to options though. However i am looking for off the shelf proven cam. Also do either of these need the pistons flycut. I have also talked to an engine builder and he says to keep the 5.3 heads on it what do you guys think?
78 l92
03-12-2012, 11:06 PM
more info needed
xpndbl3
03-13-2012, 12:34 AM
call EPS and get a cam for a single plane intake, not one made for efi
bitterman
03-13-2012, 06:46 AM
Either Geoff @ EPS of Patrick G are my votes. a custom cam is especially important when going carb other wise you leave a lot of power on the table.
Also just using a cam someone else has had spec may not be the best unless everything is a complete carbo copy down to gear ratios, stall,expectation, tire size and weight of the vehicle etc etc.
Bruce
ZONES89RS
03-13-2012, 07:36 AM
Have used the torqer on a 6.0, worked bad ass.
Brandon331
03-13-2012, 09:02 AM
custom grind cam dont use a off the shelf cams..i also wouldnt reccamend any comp cams ive seen so many comp cams that have been going bad with cam lobe failers and stuff...
richard david
03-13-2012, 10:11 AM
Get a custom cam and get rid of that elderbrock 750 you pick up half a sec.with a good holley
