Locking Fuel Door
Old 03-13-2012, 10:40 AM
HibachiZ28's Avatar
Question Locking Fuel Door
Does anyone offer a locking fuel door for the Trans Am? Something that's a STOCK look/style, just with a lock of some sort? With gas prices on a steady rise I'd enjoy having something there to deter gas thieves.
Old 03-13-2012, 10:54 AM
MasterV8's Avatar
Don't know about door! But I have a locking cap.
Old 03-13-2012, 11:04 AM
HibachiZ28's Avatar
I like the OE cap, but a locking cap is next on the list if I can't find a door. Is yours a GM locking cap or aftermarket? If aftermarket, do you have a link? Thanks.
Old 03-13-2012, 12:07 PM
MasterV8's Avatar
Unfortunately not! I asked the guy that imported my car & he ordered it for me along with locking wheel nuts, I'm pretty sure it came in a GM box though & it's a perfect fit.
Edit: I can try & have a quick look tonight when I get home and see if there's a serial number on it.
Old 03-13-2012, 01:04 PM
HibachiZ28's Avatar
Not to worry! I'll call up the old GM dealer I used to work at and see what they have for me. Much appreciative of the offer, though.
Old 03-13-2012, 04:12 PM
SparkyJJO's Avatar
I know you can get locking gas caps from Stant I believe, the thing is they don't have the nice little tether on the cap.
Old 03-13-2012, 04:17 PM
Copy & Paste Moderator
VIP1's Avatar
I had a Stant locking gas cap for a short while. The locking mechanism became unreliable in less than a year (I had a hard time getting the cap off) so I went back to the stock cap. Also, the key is a non-standard size and I couldn't find someone to make a copy.
I wonder what can be done for the 2010+ Mustangs since they don't have gas caps.
Old 03-13-2012, 05:20 PM
01badbird's Avatar
Well working on something along those lines right now.Recently filled in rear keyhole (for light up BADBIRD) so hooking up a latch to pull to pop hatch in case battery dies (located in rear) and not able to get to. I wanted a pic on lever of rear hatch so snooped around and found latch for fuel/hatch and thought that would be different and help smooth out look. Got door off gm truck and is just crimped on.
Old 03-13-2012, 09:20 PM
Super-Bat's Avatar
^Write up? That looks awesome, and I've been wishing our cars came with that ever since I met my gf and the past 2 cars she's had have had that type of gas door.
Old 03-13-2012, 09:55 PM
SparkyJJO's Avatar
I want to see this done! That's sweet.
Old 03-14-2012, 10:25 AM
sweetbmxrider's Avatar
Have you tried siphoning fuel out of your tank? I've had no such luck......I'm not a professional thief though!
Old 03-14-2012, 10:52 AM
MasterV8's Avatar
It's not just taking out, it's stopping vindictive ******** putting stuff in.
Old 03-15-2012, 10:32 AM
Sucks you have that problem. OP stated he wanted to stop gas thieves. I stated that you can't siphon these tanks. Props to the guy making the cable release door, that is interesting.
Old 03-15-2012, 10:44 AM
SparkyJJO's Avatar
Yes you can.
I siphoned 10 gallons of gas out of the tank of my old Camaro after the accident so I could put it in my Trailblazer. I didn't use anything fancy to do it.
Old 03-15-2012, 01:37 PM
david068513's Avatar
Do it like most road race cars. put a pull string in the hatch and it won't open without that string pulled.
Old 03-15-2012, 02:00 PM
HibachiZ28's Avatar
I've siphoned gas out of almost anything that runs off of it. I used to have a squeeze pump siphon like the large VP drums have. Worked really well for getting gas out of my 10 gallon "drum" into my lawn mower.
Old 03-15-2012, 02:04 PM
aquariussuperman's Avatar
Any part numbers you could share for the gas cap cover? Thanks.
Old 03-16-2012, 10:52 AM
I am very impressed then. I have tried both plastic and metal fbody tanks with no luck.
OP, I suggest you try it before going further with your project. I'm probably just a newb though
Old 03-16-2012, 04:22 PM
01badbird's Avatar
The easy part is putting on different door GM pickups,blazers,vans seem to have 6 inch round door without raised notch.Went to junk yard and looked around and got 93-97 door/hinge and door/hinge off pickup.just have to uncrimp and recrimp on new one.I have to get bracket welded on and respring to open when cable is pulled.Also making pod for levers next to seats. been busy so this might just get it done.heres some pics if it helps
Attached Thumbnails Locking Fuel Door-93-97-door-hinge.jpg   Locking Fuel Door-98-stock-door.jpg   Locking Fuel Door-both.jpg   Locking Fuel Door-hinge-new-door.jpg
Old 03-16-2012, 09:32 PM
Super-Bat's Avatar
Hm... wanna make another and sell it?
Quick Reply: Locking Fuel Door
