Nitrous Oxide - Vic Junior guys, where are you mounting solenoids. Pics would be appreciated.
armyboyatc
03-13-2012, 01:30 PM
As the title says. I need to mount my solenoids but need to know where to mount them and where to buy or how to make the brackets.
Im running a vic junior 4150 TB setup.
soundengineer
03-13-2012, 03:11 PM
Victor Series Solenoid Bracket by Nitrous Outlet....
Simple, Elegant, Sexy.....Reasonably Priced
Mine is a Super Victor, but the bracket fits both the Super Vic and the Vic JR
http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/Nitrous%20Install/IMAG0149.jpg
http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/Nitrous%20Install/IMAG0186.jpg
http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/Nitrous%20Install/IMAG0221.jpg
krissoto
03-13-2012, 07:37 PM
Not tying to hijack but soundengineer, Can u notice a diff when running the elbow to not? I have heard that it can hold back a few ponies
soundengineer
03-13-2012, 07:45 PM
I have the "Pro" series Extreme velocity elbow... its does better than everything else out there...
and honestly, something to direct the airflow into the intake is better than nothing at all...
on the dyno you may see a difference from an elbow to none at all because you are sitting still...
but dont forget that while you are going down the track you get a mild super charging effect that you cant get on a dyno(unless you have a fan moving air at the same speed as your tires are going and displacing as much air as your moving vehicle does...)
as long as the tube going up to the TB flows more and can capture more air than the TB itself... you will be just fine
simple physics....and physics always wins
Nitro Dave's Nitrous Outlet
03-13-2012, 11:01 PM
Thanks for sharing the pics Scott. :-)
We have another bracket set up that I will try to get pics off tommorow. We can also build custom solenoid brackets.
Dave
armyboyatc
03-14-2012, 09:30 PM
I have a plate kit. Direct port is awesome though.
soundengineer
03-14-2012, 10:48 PM
the bracket I show doesnt have to be used with a direct port....
Its Universal...
Just take your lines from your solenoids up to your plate...
AChotrod
03-14-2012, 11:19 PM
Im gonna try the eldelbrock bracket but not sure that it will clear my 860 elbow. Should know soon when I actually bolt on the noids
armyboyatc
03-15-2012, 07:08 AM
Its Universal...
Good deal. I will be calling nitrous outlet and getting that setup.
lsxTAlemy
03-15-2012, 07:51 AM
love the victor setups. they look mean. im thinking of going with a same setup...
10secZ28
03-15-2012, 08:17 AM
Dave is the man!!!
armyboyatc
03-15-2012, 09:20 AM
You should. Nothin like a chevy motor with a single plane intake on it. It looks beast mode.
MikeFSKSpeed
03-15-2012, 09:27 AM
Edelbrock has the nice plate for 2 or 4 solenoids, I keep them in stock ;)
http://static.atechmotorsports.com/global/images/prod/large/EDL-72289.jpg
minytrker
03-15-2012, 11:29 AM
Nitrous outlet bracket with Vic jr
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
