ryangtp89
03-13-2012, 06:52 PM
My '98 camaro M6 has been sitting in the garage for about 4 months since i last started it. The battery wasnt complety dead but not enough juice for it too start soo i had to jump start it. I unhooked the battery while it sat, thinking it would keep the battery alive, i'm not soo smart huh.
I get it started and it idles alittle above 2000rpm and it does that the entire time, i let it sit for 10mins. White smoke only appeared for 15 seconds and thats it, soo the motor seems healty. I give it a couple quick jabs at the throttle and it the rpms drop slowly when i let off. Soo i take it out for a ride, i just installed my pro 5.0 before i started it up. I got to say that getting into reverse is a pain in the ass. Seems like 1st gear makes some chattering. The shifting seems sloppy along with the high idle. I'm thinking i might need a clutch ? It likes to grind when i go into gears sometimes. I know i didnt get you much info but its late and i just came in from inside.
If i get a clutch what clutch should i go with that wont break the bank ? My car is stock and i plan on doing some bolt ons this summer. I heard something about ram clutches? I will probably get a slave cylinder for it, and i heard alot about ticks adjustable master cylinder?
I have no clue if the pcm was relearning because i unhooked the battery or not, but i let it idle for about 10 minutes i drove it down the road several times, did a few WOT runs, but still idles high. And i could defently feel the heat from the tranny when i got into the garage, i left the console off.
My buddy works at a shop and hes going to see if his boss will let us work on it during the weekends for a small price, but i still dont want to throw alot of money at it if i dont need too.
I still need to see when my driveshaft is still leaking, i just replaced a rear pinon seal.
