Advanced Engineering Tech - someone help with clearance issue
chrisrhino
03-13-2012, 08:47 PM
i am putting a stock ls1 motor together and i just bought some ls6 317 casting prc heads that are 66cc and shaved 30 thousands i am wanting to go with the f14 highlift cam. should there be any clearance issuue's with this setup.
BigRich954RR
03-14-2012, 06:10 AM
are you joking this is not advanced tech and your planning to clay the engine right ?
Old Geezer
03-14-2012, 03:24 PM
This forum is a dumping ground for every "engine 101" ?? in the book....:eyes:
techls1
03-28-2012, 08:33 AM
Did you take an additional .030 off or is that what they came with? I have those heads with their V3 cam which is similar to the F14 and have not had a clearance problem. However I would run the Stock gaskets since they are a little taller and not the Cometic ones.
Ethan[ws6]
04-05-2012, 12:22 AM
clay it. only way to know for sure. standard clearance specs for PTV: Intake .080" Exhaust .100"
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
